[moved] X-Openoffice 2.3 from English to German ?Go to page << |
| Taf |
![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3379 ![]() | For me the link is working properly! ..is pointing to UPXSHELL, present in our site (portable). | ||
| Peter G |
![]() ![]() Registered Member #5718 Joined: Tue 14 Aug 2007 - 21:38Posts: 21 | I don't know ....... now I have the zip ....... How does UPX work ? I guess, I have to apply it on the copied folders in the X-Openoffice-tree ....? | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Hi Peter G, X-UPXShell is of very simple use... First of all, goto "English_users" folder and read instructions to localize in English. Then, run X-UPXShell.exe; it should open on "Options" tab, otherwise click on it. In the lower right corner you find "Multipack" button; click it. This will open a new form; from there you can "Browse" to X-OpenOffice folder (please be sure that "Recurse Subdirectories" is checked) and select from the top combo box "*.* (Any file)". "Pack" button will do the job; obviously, just UPX-supported files will be packed (if not already packed). Try and let me know... Best Regards ZioZione | ||
| Peter G |
![]() ![]() Registered Member #5718 Joined: Tue 14 Aug 2007 - 21:38Posts: 21 | Fine ......... ..... I will try it at the weekend ................ I will report ![]() | ||
| Peter G |
![]() ![]() Registered Member #5718 Joined: Tue 14 Aug 2007 - 21:38Posts: 21 | Well I did it ! And it indeed worked. But it was a little bit mysterious ...... the UPXShell have brought error-messages for each file ("Fehlgeschlagen") .... ... but in fact there was a compression of about 60 MB !!!! So my german version has now about the 280 MB (including Java). Thats fine ! (and that is of course smaller than my first version using your winpenpack original with the german language pack) I have tested it, it works ..... including the start windows of OOo (asking for username, licencese aggrement ...... because I haven't startet my original OOo on my PC before copying the files to the portable version). From my first feel, the plain german version is faster and more "handy" like the multilingual version ..... Thanks a lot ...... | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Peter G wrote ... Well I did it ! And it indeed worked. Hi Peter G, well, fine... Peter G wrote ... But it was a little bit mysterious ...... the UPXShell have brought error-messages for each file ("Fehlgeschlagen") .... This could be right: "Fehlgeschlagen" (in english: "Failed") is the message for files that could not be compressed (either because they are already UPX-compressed or they are not in the list of UPX-able files). But this error (as you seen) is not a blocking error. Consider it just an alert, also for better understanding what can be compressed with UPX and what could not. Best Regards ZioZione [ Edited Mon 24 Sep 2007 - 11:03 ] | ||
Go to page <<
