Aggiornamento: Miranda Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.10.4 Link winPenPack Updated from version 0.10.3 to 0.10.4 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.10.5 Link winPenPack Updated from version 0.10.4 to 0.10.5 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.10.6 Link winPenPack Updated from version 0.10.5 to 0.10.6 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.10.8 Link winPenPack Updated from version 0.10.6 to 0.10.8 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download [ Edited Mon 05 Nov 2012 - 22:25 ] | ||
vix |
Registered Member #11044 Joined: Sat 10 May 2008 - 15:17Posts: 27 | Mi permetto una segnalazione: il Direct Link nel post di annuncio della v 0.10.8 punta al file di installazione *.exe. Occorrerebbe modificarlo con quello corretto al *.7z, altrimenti le istruzioni nella pagina di download non sono più valide. grazie | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Link corretto! Ciao vix e grazie per la segnalazione. | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.10.9 Link winPenPack Updated from version 0.10.8 to 0.10.9 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.10.10 Link winPenPack Updated from version 0.10.9 to 0.10.10 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.10.11 Link winPenPack Updated from version 0.10.10 to 0.10.11 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Miranda 0.10.12 Link winPenPack Updated from version 0.10.11 to 0.10.12 Home: -Link- Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- Risultato test: seguire le istruzioni della pagina download | ||
