Aggiornamento: MirandaGo to page << >> |
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | X-Miranda verrà dismessa, al suo posto segnaleremo la versione "nativamente" portabile. Grazie X-Miranda will be dismissed, instead we'll support the "native" portable Miranda version. Thank you. --- edit --- Inserito in download (in una nuova scheda) Miranda IM 0.28.3 portabile; rimosso dal database X-Miranda. Now is in download Miranda IM 0.28.3 portable; X-Miranda was removed from database. [ Edited Fri 21 May 2010 - 00:47 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Miranda 0.8.24 Link winPenPack Aggiornamento dalla versione 0.8.23 alla 0.8.24 Home: -Link- ![]() Direct Link: EXE (Windows NT, 2000, XP, Vista only) -Link- ![]() Direct Link: ZIP (Windows NT, 2000, XP, Vista only) -Link- ![]() --- edit zandet2 --- Risultato test: niente da segnalare [ Edited Wed 09 Jun 2010 - 23:31 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Miranda 0.8.25 Link winPenPack Aggiornamento dalla versione 0.8.24 alla 0.8.25 Home: -Link- ![]() Direct Link: EXE (Windows NT, 2000, XP, Vista only) -Link- ![]() Direct Link: ZIP (Windows NT, 2000, XP, Vista only) -Link- ![]() --- edit zandet2 --- Risultato test: niente da segnalare scheda di download aggiornata [ Edited Thu 10 Jun 2010 - 10:51 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Miranda 0.8.26 Link winPenPack Aggiornamento dalla versione 0.8.25 alla 0.8.26 Home: -Link- ![]() Direct Link: EXE (Windows NT, 2000, XP, Vista only) -Link- ![]() Direct Link: ZIP (Windows NT, 2000, XP, Vista only) -Link- ![]() --- edit zandet2 --- Risultato test: niente da segnalare scheda di download aggiornata [ Edited Fri 25 Jun 2010 - 11:03 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Miranda 0.8.27 Link winPenPack Aggiornamento dalla versione 0.8.26 alla 0.8.27 Home: -Link- ![]() Direct Link: EXE (Windows NT, 2000, XP, Vista only) -Link- ![]() Direct Link: ZIP (Windows NT, 2000, XP, Vista only) -Link- ![]() ---edit zandet2 --- Risultato test: niente da segnalare [ Edited Sun 04 Jul 2010 - 11:37 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Miranda 0.9.0 Link winPenPack Aggiornamento dalla versione 0.8.27 alla 0.9.0 Home: -Link- ![]() Direct Link: EXE (Windows NT, 2000, XP, Vista only) -Link- ![]() Direct Link: ZIP (Windows NT, 2000, XP, Vista only) -Link- ![]() Risultato test: ![]() | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Miranda 0.9.1 Link winPenPack Aggiornamento dalla versione 0.9.0 alla 0.9.1 Home: -Link- ![]() Direct Link: EXE (Windows NT, 2000, XP, Vista, 7) -Link- ![]() Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- ![]() Risultato test: ![]() | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Miranda 0.9.2 Link winPenPack Aggiornamento dalla versione 0.9.1 alla 0.9.2 Home: -Link- ![]() Direct Link: EXE (Windows NT, 2000, XP, Vista, 7) -Link- ![]() Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- ![]() --- edit zandet2 --- Risultato test: niente da segnalare Nota: aggiornata scheda download con versione compressa 7z e rimando a X-7zip per l'estrazione [ Edited Thu 09 Sep 2010 - 17:40 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Miranda 0.9.3 Link winPenPack Aggiornamento dalla versione 0.9.2 alla 0.9.3 Home: -Link- ![]() Direct Link: EXE (Windows NT, 2000, XP, Vista, 7) -Link- ![]() Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- ![]() Risultato test: ![]() [ Edited Sat 11 Sep 2010 - 10:02 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Miranda 0.9.4 Link winPenPack Aggiornamento dalla versione 0.9.3 alla 0.9.4 Home: -Link- ![]() Direct Link: EXE (Windows NT, 2000, XP, Vista, 7) -Link- ![]() Direct Link: 7Z (Windows NT, 2000, XP, Vista, 7) -Link- ![]() --- edit zandet2 --- Risultato test: niente da segnalare [ Edited Thu 30 Sep 2010 - 14:06 ] | ||
