Aggiornamento: FreeCommander Go to page << |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | FreeCommander 2009.02 Link winPenPack Aggiornamento dalla versione 2008.06c alla 2009.02 Home: -Link- Direct Link: -Link- Risultato test: niente da segnalare [ Edited Sun 22 Feb 2009 - 16:40 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | FreeCommander 2009.02a Link winPenPack Aggiornamento dalla versione 2009.02 alla 2009.02a Home: -Link- Direct Link: -Link- Risultato test: niente da segnalare [ Edited Mon 16 Nov 2009 - 14:59 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | FreeCommander 2009.02b Link winPenPack Aggiornamento dalla versione 2009.02a alla 2009.02b Home: -Link- Direct Link: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | FreeCommander XE 2014 (release 650) Link winPenPack Aggiornamento dalla versione 2009.02b alla XE 2014 (release 650) Home: -Link- Direct Link: -Link- Estrazione e uso/How to extract and use: [It] decomprimere l'archivio.zip, prima di avviare FreeCommander.exe creare il file fcStart.ini all'interno della directory del programma col seguente contenuto: [Start] freeCommanderIniDir=%FcSrcPath% [En] extract the ZIP package to any folder of your choice, before the first run of FreeCommander.exe, please create a fcStart.ini file in the program folder with the following content: [Start] freeCommanderIniDir=%FcSrcPath% [ Edited Sat 31 Jan 2015 - 16:48 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | FreeCommander XE 2015 Build 685 Link winPenPack Aggiornamento dalla versione XE 2014 (release 650) alla XE 2015 Build 685 Home: -Link- Direct Link: -Link- Risultato test: niente da segnalare [ Edited Sat 31 Jan 2015 - 18:17 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | FreeCommander XE 2016 Build 715 Link winPenPack Aggiornamento dalla versione XE 2015 Build 685 alla XE 2016 Build 715 Home: -Link- Direct Link: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | FreeCommander XE 2017 build 740 Link winPenPack Aggiornamento dalla versione XE 2016 Build 715 alla XE 2017 build 740 Home: -Link- Direct Link: -Link- Risultato test: niente da segnalare | ||
Go to page <<
