VLC 0.8.6d |
| JackL |
![]() ![]() Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | Hi, anybody is skilled enough to prepare it in x version ? :] cheers JackL | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Hi JackL, where did you find news about 0.8.6d version? In main site there is only 0.8.6c... Best Regards ZioZione | ||
| JackL |
![]() ![]() Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | -Link- but also by google in other places | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Hi JackL, thanks, I will download in a while... But are you sure is an official one? Best Regards ZioZione | ||
| JackL |
![]() ![]() Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | no insurance :] | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Hi JackL, "nice" to hear... but our policy is, usually, to wait for official releases before creating corresponding X-programs, so I think that, for an official release of X-VideoLAN_0.8.6d, you have to wait a little... In any case (at your own risk...) you can uncompress installation program with Universal Extractor, i.e. into \temp\vlc (from now on we will call it "source". You will obtain some folders and files. As usual, you can delete NSIS.nsi file and $PLUGINSDIR folder. Base folder for copying into is \Bin\videolan ("dest" folder). Copy all files from "source" into "dest", with the exception of axvlc.dll (to be copied into "dest"\activex folder) and npvlc.dll (to be copied into "dest"\mozilla folder). Then copy all subfolders of "source"\$[31] folder into "dest" folder. That's all. Let me know if it works. Best Regards ZioZione | ||
| JackL |
![]() ![]() Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | Thx ZZ :] btw. do you know any ortable (or not) soft to load all dlls and exes into one exe file? cheers JackL | ||
| eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2355 ![]() | What do you thnk about this program: Kantaris. Is a new opensource multimedia player based on VLC code. I don't know if it's possible to make it portable. ![]() [ Edited Fri 30 Nov 2007 - 13:30 ] | ||
| JackL |
![]() ![]() Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | Hi EagleMan, I took a look on kantaris and it seems to have some nice addition to VLC - I wonder if it's possible to add mentioned bass library to existed x-vlc :] rather than make Kantaris portable - also skin and visualization should be modular so why to bother ? cheers JackL | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | JackL wrote ... Thx ZZ :] btw. do you know any ortable (or not) soft to load all dlls and exes into one exe file? cheers JackL Hi JackL, as I know, the only program who links together .exe and .dll files is... the linker of your compiler... But, I think, you need also source code (at least for executable...). Anyway, I will search around some solution. Please, let me know if you will be more lucky than me... Best Regards ZioZione | ||
VLC 0.8.6d
