x-7-zip no plugins recognition
JackL
Thu 06 Dec 2007 - 15:40
Registered Member #6127
Hi,
Following my previous Idea about packing everything to one container, I found that it could be possible with sfx files (with RunProgram option) - provididing you have 7zS plugin - I found it but is not visible in options/plugins - is there any hint for that?
perhaps I made some mistakes in the procedure as my exe sfx files only unpack itself inspite of executing internal programs...
anyone has Idea about the possible couses?
kind regards
JackL
Thu 06 Dec 2007 - 16:05
Registered Member #74
Hi JackL,
which version of 7zS plugin are you using, 7Zip Installer SFX, as descripted by MSFN here -Link- one or Paraglider -Link- one?
This could help me a little to understand exactly the enviroment where you are moving...
Best Regards
[ Edited Thu 06 Dec 2007 - 16:24 ]
JackL
Thu 06 Dec 2007 - 17:11
Hi, I used one from paraglider site
cheers
Thu 06 Dec 2007 - 17:21
Hi JackL,
I think it have to be configured manually, as depicted in plugin Usage page ( -Link- see bottom of page...).
Furthermore, if you take a look to 7Zip Help, you can find analogous method under "Command Line version|Switches|-sfx". Hope it helps.
Best Regards
[ Edited Thu 06 Dec 2007 - 17:25 ]
