x-7-zip no plugins recognition |
| JackL |
![]() ![]() Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | Hi, Following my previous Idea about packing everything to one container, I found that it could be possible with sfx files (with RunProgram option) - provididing you have 7zS plugin - I found it but is not visible in options/plugins - is there any hint for that? perhaps I made some mistakes in the procedure as my exe sfx files only unpack itself inspite of executing internal programs... anyone has Idea about the possible couses? kind regards JackL | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Hi JackL, which version of 7zS plugin are you using, 7Zip Installer SFX, as descripted by MSFN here -Link- one or Paraglider -Link- one? This could help me a little to understand exactly the enviroment where you are moving... Best Regards ZioZione [ Edited Thu 06 Dec 2007 - 16:24 ] | ||
| JackL |
![]() ![]() Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | Hi, I used one from paraglider site cheers | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Hi JackL, I think it have to be configured manually, as depicted in plugin Usage page ( -Link- see bottom of page...).Furthermore, if you take a look to 7Zip Help, you can find analogous method under "Command Line version|Switches|-sfx". Hope it helps. Best Regards ZioZione [ Edited Thu 06 Dec 2007 - 17:25 ] | ||
