Aggiornamento: PDF-XChange Viewer Portable Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.210 Link winPenPack Aggiornamento dalla versione 2.5.209 alla 2.5.210 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.211 Link winPenPack Aggiornamento dalla versione 2.5.210 alla 2.5.211 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.212 Link winPenPack Aggiornamento dalla versione 2.5.211 alla 2.5.212 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare [ Edited Sat 31 Aug 2013 - 23:11 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.213 Link winPenPack Aggiornamento dalla versione 2.5.212 alla 2.5.213 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
sceicco |
Registered Member #5022 Joined: Tue 05 Jun 2007 - 08:51Posts: 385 | PDF-XChange Viewer Portable 2.5.213.1 Link winPenPack Aggiornamento dalla versione 2.5.213 alla 2.5.213.1 Home: -Link- Direct Link: -Link- Risultato Test: niente da segnalare [ Edited Thu 14 Nov 2013 - 23:51 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.214 Link winPenPack Aggiornamento dalla versione 2.5.213.1 alla 2.5.214 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.214.1 Link winPenPack Aggiornamento dalla versione 2.5.214 alla 2.5.214.1 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.214.2 Link winPenPack Aggiornamento dalla versione 2.5.214.1 alla 2.5.214.1 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.308.0 Link winPenPack Aggiornamento dalla versione 2.5.214.1 alla 2.5.308.0 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.308.1 Link winPenPack Aggiornamento dalla versione 2.5.308.0 alla 2.5.308.1 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
