CPUMon
Thu 31 Jan 2008 - 20:57
Registered Member #675
Nome del software: CPUMon
Dimensione File: (425 Kb)
Nome autore: Denis Kozlov
eMail autore: -eMail-
Descrizione: CPUMon è una piccola utility per monitorare le prestazione della CPU. Mostra un grafico in tempo reale delle prestazione della CPU e il corrispondente indicatore di utilizzo.
Portable tips how-to: Decomprimere l'archivio .zip e lanciare il file CPUMon.exe
Versione: 1.60
Licenza: Creative Commons License
Description: CPUMon is a simple little gadget to monitor CPU performance from your desktop. It displays a real-time graph of CPU performance as well as current usage indicator. The display supports custom colors, alpha-blending, user defined update rates and more. Some of the features: transparency, alpha-blending, customizable colors, layout presets, form locking, constantly updated CPU speed for Mobile processors, plus Tray Icon mode and Statistics, can also display Memory Usage, etc... Comes with "Carbonsoft cxCpu Processor Detection Toolkit", which provides: * CPU Explorer - detailed CPU information, supports multiple CPUs; * CPU Features - lists supported CPU features.
[ Edited Fri 01 Feb 2008 - 16:00 ]
Thu 12 Mar 2009 - 16:25
Aggiunto al database: -Link-
