[Transcoder] MediaCoder Audio Edition
Wed 06 Feb 2008 - 12:17
Nome del software: MediaCoder Audio Edition
Direct Link al download: -Link- (nota: è presente solo il file .exe e non il file .7z)
Dimensione File: 8312846
Nome autore: Stanley Huang
eMail autore:
Descrizione: Convertitore audio - sottoprogetto di MediaCoder dedicato al formato audio
Versione: 0.6.1.4046
Licenza: Mozilla Public License 1.1 (MPL 1.1)
Portable tips how-to:
1) Estrarre i file da MediaCoderAE_versione_.exe con Universal Extractor in una cartella (possibilmente con un nome diverso da mediacoder)
2) muovere le sottocartelle
\Application Data
\chrome
\defaults
dalla cartella "\$[31]" alla cartella "\xulapp"
3) muovere le sottocartelle
\htdocs
\lang
dalla cartella "\$[31]" alla cartella principale
4) Eliminare le cartelle
\$[31]
\$COMMONFILES
\$PLUGINSDIR
e il file [NSIS].nsi
5) Avviare l'applicazione lanciando mediacoder.exe
Dal sito:
MediaCoder Audio Edition is an audio transcoding tool based on MediaCoder. It nicely integrates many audio codecs and tools into an all-in-one software. It decodes almost all popular formats of audio files as well as audio stream in video files and encodes them with all its supported (and even some not claimed supported) audio encoders. All the codecs are included in the standalone software. With CUE Sheet and DVD/VCD/CD support and many additional features, audio enthusiasts can convert all their favorite music freely to any format on-the-fly and in batch.
Audio encoders included:
* LAME MP3 3.98b6 (x64 build available)
* OggEnc v2.84 (aoTuVr1) / 2.83 (Lancer SSE2)
* Nero AAC Encoder 1.1.34.2
* FAAC 1.26.1
* Enhanced 3GGP AAC+ Encoder (x64 build available)
* Helix MP3 Encoder v5.1
* MusePack Encoder 1.16
* Speex Encoder 1.2beta1
* FFmpeg SVN-trunk
* WavPack Encoder 4.41.0 (x64 build available)
* FLAC Encoder/Decoder 1.2.0 (x64 build available)
* Monkey's Audio Codec 4.0 (x64 build available)
* TTA Encoder 3.4.1
* OptimFrog Encoder v4.6
* MPEG-4 Lossless Encoder
[ Edited Fri 05 Nov 2010 - 21:54 ]
Bourne
Wed 06 Feb 2008 - 19:32
Registered Member #4287
Ho provato con l'eseguibile della nuova 4048, alcune note/info dopo aver estratto con Universal:
1- non e' presente la cartella $COMMONFILES
2- non e' portabile (la versione in archivio 7z invece lo era), crea le due seguenti chiavi (con valori):
Keys added:2
HKU\S-1-5-21-57989841-602609370-725345543-1003\Software\Zyrax Software
HKU\S-1-5-21-57989841-602609370-725345543-1003\Software\Zyrax Software\VolEqu
Values added:1
HKU\S-1-5-21-57989841-602609370-725345543-1003\Software\Zyrax Software\VolEqu\Dump0: C0 5D 00 00 14 00 00 00 C8 00 00 00
Detto questo, pare essere un programma che richiede l'engine di un browser (firefox) per la renderizzazione di alcune sue opzioni .
ciao
[ Edited Wed 06 Feb 2008 - 19:33 ]
Wed 06 Feb 2008 - 21:34
Ciao Bourne,
se è così allora la segnalazione va spostata in *Richieste portabilizzazione* ....sorry staff
non me ne ero accorto, l'avevo dato per buono visto che è una "specializzazione" del progetto principale
L'ini è facilmente scrivibile, ma a questo punto si può creare una x-version...
Per Firefox invece, il problema è comune con Mediacoder versione completa, in quanto questa è una derivazione; comunque è possibile inserirlo in una struttura WPP, dando come riferimento il percorso relativo di X-Firefox
--EDIT--
La cartella $COMMONFILES è presente tra quelle estratte da UniExtract...
sottolineo che la versione da te indicata 4048 è quella di MediaCoder "versione completa", quella di AudioEdition è 4046, sono due progetti collegati ma diversi (probab. tra un po' apparirà anche qui la versione 4048)
n.b. MediaCoder "versione completa" non scrive la voce nel registro (ho appena verificato), quindi un eventuale ini servirebbe solo per la AudioEdition; la chiave Zyrax è generata dal servizio/plugin di normalizzazione audio Zyraxs Evil Volume Normalizer -Link- , incapsulato in plugins\dsp_zsc.dll (Heuristical Sound Studio).
ciao
[ Edited Thu 07 Feb 2008 - 01:04 ]
Thu 07 Feb 2008 - 13:24
Bourne wrote ...
Detto questo, pare essere un programma che richiede l'engine di un browser (firefox) per la renderizzazione di alcune sue opzioni.
Ecco cosa dicono sul sito: -Link-
Can MediaCoder function without Firefox
MediaCoder does not reply on Firefox to perform transcoding (that doesn't make any sense). However some extended user interfaces (developed with XUL) depend on Firefox (more accurate, its Gecko engine). If you don't need those UI, you don't have to install Firefox. Neither do you need to be online to use MediaCoder.
Non solo, questo è tra i propositi futuri: -Link-
dipendere totalmente da XUL
Here I list some of my thoughts about the major new features of the next version:
* Fully XUL-based user interface (the classic user interface will be kept of course)
La vedo dura...
Comunque, ecco il loro metodo per renderlo portabile: -Link-
copiarsi Firefox intero dentro MediaCoder!!!!
To make MediaCoder a portable application that can be launched from USB storage (or the storage of your media player) on different PCs, follow these steps:
* Download a copy of MediaCoder and install it.
* Start MediaCoder and on the welcome page, choose "Do not show this page on next startup".
* If you don't have Firefox installed, please download and install it.
* Create a folder named "Firefox" in MediaCoder's installation folder. Copy all files and sub-folders in Firefox's installation folder (e.g. C:\Program Files\Mozilla Firefox) to the created folder (e.g. C:\Program Files\MediaCoder\Firefox).
* Copy MediaCoder's installation folder to your USB storage or your media device storage.
And that's all. Now you can take MediaCoder with you anywhere you go.
Ora la palla passa ai "portabilizzatori"...
ciao
Bourne
Thu 07 Feb 2008 - 13:42
zandet2 wrote ...
Si', hai ragione, avevo scaricato la 4048 completa (sotto forma di exe) della versione "ufficiale", ed e' testando quella che sono state create quelle chiavi (Zyrax) nel registro.
Per prova ho successivamente chiuso il programma, cancellato dal registro quelle chiavi e riaperto il programma: le chiavi vengono ricreate.
ciao
Thu 07 Feb 2008 - 14:45
NOTA: si parla di MediaCoder versione completa 4048
Ok, risolto l'arcano.
La versione .exe e la versione .7z sono diverse!!!!
Nella versione install sono presenti in più nella cartella plugins due dll: dsp_chmx.dll (channel mixer) e dsp_zsc.dll (Heuristical Sound Studio); la seconda è quella che scrive le voci "Zyrax" nel registro, proprio come succede per la AudioEdition...
In esecuzione, la differenza tra le due versioni .exe/.7z è che nel tab Plugins nel primo caso (exe) sotto la voce Audio DSP Plugins troviamo Channel Mixer 1.1 e Heuristical Sound Studio, nel secondo caso (7z) non è presente nessuna voce.
Ipotizzo: probabilmente la versione 7z è stata resa portabile in modo "brutale" dall'autore, eliminando le dll che scrivono nel registro...
Indi per cui... la versione .7z è nativamente portabile, la versione .exe no....
ciao
Wed 13 Feb 2008 - 12:44
In attesa della decisione se considerarlo tra i software da portabilizzare, segnalo l'aggiornamento alla nuova versione:
0.6.1.4050 (2008-02-12)
Pagina web: -Link-
Download 32 bit: -Link-
Download 64 bit: -Link-
ciao
[ Edited Wed 13 Feb 2008 - 12:45 ]
Sun 01 Feb 2009 - 01:30
zandet2 wrote ...
eMail autore:
Versione: 0.6.2.4255 (20.1.09)
Test sulla portabilità: da effettuare
