X-Opera Launcher Go to page >> |
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Ecco una prima versione del super richiesto launcher per Opera. Download X-Opera Launcher 1.1 [rev1]: -Link-
[ Edited Sun 11 May 2008 - 01:03 ] | ||
sceicco |
Registered Member #5022 Joined: Tue 05 Jun 2007 - 08:51Posts: 385 | Mitico Danix, volevo chiederti se nel launcher da te compilato hai tenuto conto di questi 2 passaggi che ho trovato sul sito della versione - Opera@USB, e precisamente: Riporto come scritto Opera - FAQ Does permanent access damage the USB stick? To safe livetime of the USB Device and to increase speed of Opera, the cache-directory is on the harddisk (at Windows temp) the Cache was cleared after normal close of Opera, so there is no data left. I like to use the Sessions function ? The Sessions function was disabled (Continue from last time) so Opera don't always writes the actual state to the stick To activate the "Continue from last time" / Sessions - function , you have only to delete the sessions file in the operausb\profile\ directory - thats all ! Ciao! | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | sceicco wrote ... Does permanent access damage the USB stick? To safe livetime of the USB Device and to increase speed of Opera, the cache-directory is on the harddisk (at Windows temp) the Cache was cleared after normal close of Opera, so there is no data left. Ovvio La cache viene salvata in una directory temporanea anzichè nel profilo personale per poi esser cancellata alla chiusura dell'applicazione. Esattamente in C:\Documents and Settings\Nome_Utente\Impostazioni locali\Temp\Opera La cartella "Opera" rimane su Hd vuota, ma volendo potrei inserire un'istruzione per eliminarla. ------------------------------------------------ [rev2] Linea 38, aggiungere:
DirRemove=@TempDir@\Opera
(ho aggiornato il launcher) ------------------------------------------------ sceicco wrote ... Non ho disabilitato invece questa funzione. Non ne ero neanche a conoscenza. Che sarebbe? Se si elimina il "sessions file" non si crea il profilo?I like to use the Sessions function ? The Sessions function was disabled (Continue from last time) so Opera don't always writes the actual state to the stick To activate the "Continue from last time" / Sessions - function , you have only to delete the sessions file in the operausb\profile\ directory - thats all ! [ Edited Sun 23 Sep 2007 - 17:10 ] | ||
alexcyber |
Registered Member #5886 Joined: Thu 30 Aug 2007 - 00:24Posts: 149 | ciao Danix, da molto tempo uso senza problema il tuo launcher per Opera e di questo ti ringrazio, avrei però bisogno di un aiuto, è possibile modificare il file INI(magari in maniera reversibile) per fare in modo che alla chiusura di Opera la cache non venga cancellata e venga ripristinata al successivo avvio del browser? stò usando una flat basata sui mega scaricati in up/down e mi farebbe comodo che il broswer utilizzi la cache, riducendo così il traffico di dati scambiati.... grazie [ Edited Mon 04 Feb 2008 - 15:21 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | La soluzione migliore sarebbe quella di spostare la cache in \User (anzichè lasciarla in %temp%) ed evitare che venga cancellata alla chiusura del browser. Prova a sostituire queste righe di codice in X-Opera.ini e fammi sapere.. (righe 104, 105, 106)
User Prefs|Cache Directory4=$Home$\$AppName$\cache4
(riga 112)
Disk Cache|Empty On Exit=0
alexcyber |
Registered Member #5886 Joined: Thu 30 Aug 2007 - 00:24Posts: 149 | Danix wrote ... La soluzione migliore sarebbe quella di spostare la cache in \User (anzichè lasciarla in %temp%) ed evitare che venga cancellata alla chiusura del browser. Prova a sostituire queste righe di codice in X-Opera.ini e fammi sapere.. (righe 104, 105, 106)
(riga 112)
funziona perfettamente! , forse sarebbe da valutare se inserire queste modifiche nel launcher definitivo..... grazie | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | forse sarebbe da valutare se inserire queste modifiche nel launcher definitivo..... Ho spostato la cache in %temp% proprio per evitare un'eccessiva scrittura nella cartella del programma, e quindi su USB Pen.Potrei pensare però a un'impostazione alternativa nell'INI da cambiare facilmente.. | ||
alexcyber |
Registered Member #5886 Joined: Thu 30 Aug 2007 - 00:24Posts: 149 | Potrei pensare però a un'impostazione alternativa nell'INI da cambiare facilmente.. considerando che molti utenti(io compreso) usano x-software su desktop sarebbe un' idea Ottima! | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | [rev4] Download: -Link-
[ Edited Sun 11 May 2008 - 01:16 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | [rev5] Download: -Link-
