Aggiornamento: Defraggler Go to page >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Defraggler v1.00.031 BETA Link winPenPack Aggiornamento dalla versione 1.00.023 Beta alla 1.00.031 BETA Home: -Link- Direct Link: -Link- [ Edited Thu 18 Oct 2007 - 14:23 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Defraggler v1.01.044 BETA Link winPenPack Aggiornamento dalla versione 1.00.031 BETA alla v1.01.044 BETA Home: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Defraggler v1.01.050 BETA Link winPenPack Aggiornamento dalla versione 1.01.044 BETA alla 1.01.050 BETA Home: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Defraggler v1.01.058 BETA Link winPenPack Aggiornamento dalla versione 1.01.050 BETA alla 1.01.058 BETA Home: -Link- Direct Link: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Defraggler v1.01.064 BETA Link winPenPack Aggiornamento dalla versione 1.01.058 BETA alla v1.01.064 BETA Home: -Link- Direct Link: -Link- Risultato test: niente da segnalare [ Edited Mon 17 Mar 2008 - 16:40 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Defraggler v1.01.068 BETA Link winPenPack Aggiornamento dalla versione 1.01.058 BETA alla v1.01.064 BETA Home: -Link- Direct Link: -Link- Risultato test: Chiave aggiunta:2 ---------------------------------- HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Piriform HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Piriform\Defraggler ---------------------------------- Valore aggiunto:6 ---------------------------------- HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Piriform\Defraggler\window_left: 0x00000118 HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Piriform\Defraggler\window_top: 0x00000090 HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Piriform\Defraggler\window_width: 0x000002D0 HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Piriform\Defraggler\window_height: 0x000001E0 HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Piriform\Defraggler\window_max: 0x00000001 HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Piriform\Defraggler\filelist_columns: "2;0;(0;180);(1;28);(2;70);(3;70);(4;212);" | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Queste chiavi non erano presenti nelle precedenti versioni? | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | No! non erano presenti. | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Rimosso dal database. Continuiamo a segnalare gli aggiornamenti per un pò e a monitorare, nel caso lo ripristiniamo. | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Defraggler v1.01.073 BETA Link winPenPack Aggiornamento dalla versione 1.01.068 BETA alla 1.01.073 BETA Home: -Link- Direct Link: -Link- Risultato test: identico alla versione precedente | ||
