How to update ?? |
TaZmaniak |
Registered Member #3206 Joined: Wed 07 Mar 2007 - 08:50Posts: 10 | Hi all, Beginner with WPP, i've download and install WPP 2.8 last week and see now there's a new WPP Launcher... Because i don't speak italian (i'm so sorry but i can assure you i love italian food ) i'd like to know how can i update my key with the new launcher without losing my configuration and all stuff i put in the launcher from the 2.8 ? Thanks a lot. | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | To update: - backup your winPenPack\User\winpenpack_launcher\winPenPack.xml file - overwrite winPenPack.exe - delete winPenPack\User\winpenpack_launcher\Lang folder - insert the new folder "Lang" in the same directory - insert the wppl.cur file in winPenPack\User\winpenpack_launcher\icons folder [ Edited Mon 12 Mar 2007 - 13:14 ] | ||
TaZmaniak |
Registered Member #3206 Joined: Wed 07 Mar 2007 - 08:50Posts: 10 | Thanks a lot. Saw you write it on the first page of the site also | ||
