Aggiornamento: [librerie] Java SE Runtime EnvironmentGo to page << >> |
| Taf |
![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3379 ![]() | Fatto! Grazie rbon ... ![]() [ Edited Fri 24 May 2024 - 19:25 ] | ||
| eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2379 ![]() | Java SE Runtime Environment 8 Update 421 Link winPenPack -Link- ![]() Aggiornamento dalla versione 8 Update 411 alla 8 Update 421 web site: -Link- ![]() Download page: -Link- ![]() Release date: July 16, 2024 Se poi rbon volesse mettere i link ai file portatili (che io non riesco mai a trovare), sarebbe meglio. | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 937 ![]() | Java SE Runtime Environment 8 Update 421 Portable Link winPenPack -Link- ![]() Aggiornamento dalla versione 8 Update 411 alla 8 Update 421 web site: -Link- ![]() Download page: -Link- ![]() Direct download (32 bit) Portable: jre-8u421-windows-i586.tar.gz Direct download (64 bit) Portable: jre-8u421windows-x64.tar.gz Release date: July 16, 2024 | ||
| eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2379 ![]() | Java SE Runtime Environment 8 Update 431 Link winPenPack -Link- ![]() Aggiornamento dalla versione 8 Update 421 alla 8 Update 431 web site: -Link- ![]() Download page: -Link- ![]() Release date: October, 15 2024 Se poi rbon volesse mettere i link ai file portatili (che io non riesco mai a trovare), sarebbe meglio. | ||
| eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2379 ![]() | Java SE Runtime Environment 8 Update 441 Link winPenPack -Link- ![]() Aggiornamento dalla versione 8 Update 431 alla 8 Update 441 web site: -Link- ![]() Download page: -Link- ![]() Release date: January, 21 2025 Se poi rbon (o chi ne avesse la disponibilità) volesse mettere i link ai file portatili (che io non riesco mai a trovare), sarebbe meglio. | ||
| eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2379 ![]() | Java SE Runtime Environment 8 Update 451 Link winPenPack -Link- ![]() Aggiornamento dalla versione 8 Update 441 alla 8 Update 451 web site: -Link- ![]() Download page: -Link- ![]() Release date: April, 15 2025 Se poi chi ne avesse la disponibilità volesse mettere i link ai file portatili (che io non riesco mai a trovare), sarebbe meglio. Piccola nota di servizio. Da qualche tempo a questa parte, il sito per il download della java machine è cambiato. Prima, anche da cellulare, era possibile segnalare la disponibilità delle nuove versioni. Ora si adatta automaticamente al sistema operativo in uso e propone il download della versione più adatta. Quindi conviene segnalare l'aggiornamento di questo programma esclusivamente da computer. | ||
| eagleman |
![]() ![]() Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 2379 ![]() | Java SE Runtime Environment 8 Update 461 Link winPenPack -Link- ![]() Aggiornamento dalla versione 8 Update 451 alla 8 Update 461 web site: -Link- ![]() Download page: -Link- ![]() Release date: July, 15 2025 Se poi chi ne avesse la disponibilità volesse mettere i link ai file portatili (che io non riesco mai a trovare), sarebbe meglio. Piccola nota di servizio. Da qualche tempo a questa parte, il sito per il download della java machine è cambiato. Prima, anche da cellulare, era possibile segnalare la disponibilità delle nuove versioni. Ora si adatta automaticamente al sistema operativo in uso e propone il download della versione più adatta. Quindi conviene segnalare l'aggiornamento di questo programma esclusivamente da computer. | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 937 ![]() | eagleman wrote ... Java SE Runtime Environment 8 Update 461 Link winPenPack -Link- ![]() Aggiornamento dalla versione 8 Update 451 alla 8 Update 461 web site: -Link- ![]() Download page: -Link- ![]() Release date: July, 15 2025 Se poi chi ne avesse la disponibilità volesse mettere i link ai file portatili (che io non riesco mai a trovare), sarebbe meglio. Java Offline v8.0.461 Portable PortableNAMP website: -Link- ![]() Java Offline v8.0.461 Portable - pagina di Java: -Link- ![]() Download Java Portable 32 bit: (premi il pulsante di download per 32 bit Portable) Download Java Portable 64 bit: (premi il pulsante di download per 64 bit portable) Al termine dei download si otterranno i seguenti files: 1. Per Java Portable a 32 bit: eseguibile 'Java_Portable_8.0.461_32-bit.exe' 2. Per Java Portable a 64 bit: eseguibile 'Java_Portable_8.0.461_64-bit.exe' Tali eseguibili sono files autoestraenti creati con 7-Zip. --> aprire ciascun eseguibile con 7-Zip --> Apri in 7-Zip File Manager --> salvare la cartella (ad esempio per 64 bit) 'C:\Java_Portable_8.0.461_64-bit.exe\Java_Portable_8.0.461_64-bit\bin ed inserire tale sottocartella 'bin' nel vs. programma preferito (ad esempio per X-LibreOffice) --> Lib\Java\jre1.8.0_461\bin (Java a 64 bit se X-LibreOffice è a 64 bit). | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 937 ![]() | Java SE Runtime Environment 8 Update 471 Link winPenPack -Link- ![]() Aggiornamento dalla versione 8 Update 461 alla 8 Update 471 web site: -Link- ![]() Download page for offline install: -Link- ![]() Direct download offline installer - 32 bit version: -Link- ![]() Direct download offline installer - 64 bit version: -Link- ![]() Release date: October 21, 2025 Nota: queste sono le versioni con l'installer. Non disponibili, al momento, le versioni portatili. [ Edited Thu 23 Oct 2025 - 15:46 ] | ||
| rbon |
![]() ![]() Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 937 ![]() | rbon wrote ... Java SE Runtime Environment 8 Update 471 Link winPenPack -Link- ![]() Aggiornamento dalla versione 8 Update 461 alla 8 Update 471 Java Offline v8.0.471 Portable: andare sul sito portable NAMP • PortableNAMP website: -Link- ![]() • Java Offline v8.0.471 Portable - pagina di Java: -Link- ![]() • Download Java Portable 32 bit: (premi il pulsante di download per 32 bit Portable) • Download Java Portable 64 bit: (premi il pulsante di download per 64 bit portable) Al termine dei download si otterranno i seguenti files: 1. Per Java Portable a 32 bit: eseguibile 'Java_Portable_8.0.471_32-bit.exe' 2. Per Java Portable a 64 bit: eseguibile 'Java_Portable_8.0.471_64-bit.exe' Tali files sono eseguibili autoestraenti creati con 7-Zip. Come installare Java portable v1.8.0.471: 1 andare su X-LibreOffice 2 andare sulla directory '\Lib' e poi nella sottodirectory 'Java' 3 creare all'interno di '\Lib\Java' la cartella 'jre1.8.0_471' 4 lanciare l'eseguibile autoestraente già scaricato (a seconda del vs. Windows 32 oppure 64 bit) ed estrarlo nella sottocartella 'jre1.8.0_471' 5 lanciare X-LibrerOffice (attenzione che si aggiorna automaticamente alla versione 25.2.7.2) poi andare su: 6 --> Strumenti --> Opzioni --> Avanzate: dopo qualche secondo X-LibreOffice mostra la versione '1.8.0_471' (di java) che viene riconosciuta 7 premere Applica e poi OK. 8 finito Nota se X-LibreOffice non dovesse riconoscere automaticamente la nuova versione di Java: 1 in --> Strumenti --> Opzioni --> Avanzate: premere 'Aggiungi' (in alto a destra) e poi selezionare manualmenter la cartella 'jre1.8.0_471' 2 premere Applica e poi OK 3 finito | ||
