andLinux |
Peter G |
Registered Member #5718 Joined: Tue 14 Aug 2007 - 21:38Posts: 21 | AndLinux is a Windows program that allows to run Linux Applications (on ms windows maschines). website (www.andlinux.org): -Link- For me - as a non-prgrammer - it look difficult to make that portable. | ||
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | andLinux La cosa è interessante, mi riprometto sempre di trovare il tempo ma... Comunque, basandomi esclusivamente sulle caratteristiche richieste: OS: Windows 2000 / XP / 2003 / Vista (currently only the 32-bit versions are supported) Memory: at least 128 MB (192 MB or more is recommended). Note that you should have enough memory left for Windows (at least 128 MB for Windows 2000 / XP / 2003; at least 512 MB for Windows Vista)! Hard disk space: 2.5 GB (XFCE version) / 4.5 GB (KDE version). Note that you need an NTFS file system (which is default since Windows 2000) because you can't create files larger than 2 GB on FAT(32) file systems! A good internet connection (to be able to install further applications via apt-get / Synaptic) Some basic Linux skills to proceed once andLinux is installed credo che la sezione più appropriata sia Tips & Tricks - Supporto off topic | ||
