[Fixed] X-Juice
Thu 01 May 2008 - 12:12
Nome del software: X-Juice 2.2.2-a1
Link: -Link-
Motivazione: Memorizza i percorsi assoluti all'interno del file ipodder.cfg, causando la perdita della storia dei download cambiando unità o spostando la cartella:
appdata_dir = 'D:\\Test\\X-Juice\\User\\Juice\\iPodder'
gui_dir = 'D:\\Test\\X-Juice\\Bin\\Juice\\gui'
download_dir = 'D:\\Test\\X-Juice\\User\\Juice\\iPodder\\downloads'
Proposta per il nuovo ini (con download nella cartella apposita di WPP):
AppName=Juice
[FileToRun]
[Environment]
APPDATA=$Home$\$AppName$
CFGAPPDATADIR=$Home$\$AppName$\iPodder|\\
CFGGUIDIR=$Bin$\$AppName$\gui|\\
CFGDOWNLOADDIR=$Download$\$AppName$\iPodder\downloads|\\
[Functions]
DirCreate=%APPDATA%
FileMove=$ExeDir$\images\splashscreen.bmp|$ExeDir$\images\splashscreen.bmp.original
; * locale it *
[WriteToFile=$Home$\$AppName$\ipodder\ipodder.cfg]
Line3=appdata_dir = '%CFGAPPDATADIR%'
Line4=gui_dir = '%CFGGUIDIR%'
Line5=download_dir = '%CFGDOWNLOADDIR%'
Line29=screen_language = 'it'
[Options]
DeleteTemp=true
RunWait=true
ShowSplash=false
WriteLog=false
[ Edited Sun 04 May 2008 - 02:01 ]
Sun 04 May 2008 - 02:00
Ottimo
Proporrei un paio di modifiche per permettere la localizzazione al cambio dell'ini ed evitare la creazione di sottocartelle in \Download:
AppName=Juice
[FileToRun]
[Environment]
CFGDOWNLOADDIR=$Download$\$AppName$|\\
[Functions]
DirCreate=%APPDATA%
; (en)
;FileMove=$ExeDir$\localization\catalog\it.py|$ExeDir$\localization\catalog\it.py.bak
;FileMove=$ExeDir$\localization\catalog\it.pyc|$ExeDir$\localization\catalog\it.pyc.bak
; (it)
FileMove=$ExeDir$\localization\catalog\it.py.bak|$ExeDir$\localization\catalog\it.py
FileMove=$ExeDir$\localization\catalog\it.pyc.bak|$ExeDir$\localization\catalog\it.pyc
DirRemove=%APPDATA%\iPodder\downloads
; (it)
[Options]
DeleteTemp=true
RunWait=true
ShowSplash=false
WriteLog=false
Sun 04 May 2008 - 11:53
Ok, va benissimo
ciao
Sun 04 May 2008 - 11:57
L'ho inserito in wpp_1gb_3.4
Penso sia utile
