Joined: Fri 29 Dec 2006 - 05:38 Location: Sassari Posts: 12956
Con le nuove versioni di GNU Solfege il vecchio launcher non funziona. Occorre utilizzare la REV3
------------------------------------------------------------------------------------------------ How to set language:
The language is set by default on system_default option To change language, set the environment variable in your X-Solfege.ini
; (example)
LANGUAGE=fr
; Ini revision: [rev 3]
; Date: 04.05.2008
AppName=Solfege
[FileToRun]
PathToExe=$Bin$\$AppName$\python\python.exe
Parameters=$Bin$\$AppName$\bin\solfege
[Environment]
SettingsDir=$Home$\$AppName$\settings
LessonFilesDir=$Home$\$AppName$\lessonfiles
; (set language)
;LANGUAGE=en
;LANGUAGE=it
;LANGUAGE=fr
; (locale)
Software_Locale_Dir=$Bin$\$AppName$\share
; (GTK 2.12.8 Rev A locale)
GTK_Locale_Dir=$Lib$\GTK\share
;(GTK preview version locale)
;GTK_Locale_Dir=$Lib$\GTK\lib
[Functions]
DirCreate=%SettingsDir%|%LessonFilesDir%
DirMove=@AppDataDir@\GNU Solfege|@AppDataDir@\GNU Solfege_backup
DirCopy=%SettingsDir%|@AppDataDir@\GNU Solfege|o
; (GNU Solfege preview version compatibility)
FileCopy=$Home$\$AppName$\.solfegerc|@AppDataDir@\GNU Solfege\solfegerc|o
DirCopy=$Home$\$AppName$\.solfege\statistics|@AppDataDir@\GNU Solfege\statistics|o
DirRemove=$Home$\$AppName$\.solfege
FileDelete=$Home$\$AppName$\.solfegerc
DirMove=@MyDocumentsDir@\GNU Solfege|@MyDocumentsDir@\GNU Solfege_backup
DirCopy=%LessonFilesDir%|@MyDocumentsDir@\GNU Solfege\lessonfiles|o
DirCreate=@MyDocumentsDir@\GNU Solfege\lessonfiles
DirCopy=$Bin$\$AppName$\GTK|$Lib$\GTK
DirRemove=$Bin$\$AppName$\GTK
;(it locale optional)
;DirCopy=%Software_Locale_Dir%\locale\it|%Software_Locale_Dir%\locale_it\it
;DirRemove=%Software_Locale_Dir%\locale
;DirMove=%Software_Locale_Dir%\locale_it|%Software_Locale_Dir%\locale
;DirCopy=%GTK_Locale_Dir%\locale\it|%GTK_Locale_Dir%\locale_it\it
;DirRemove=%GTK_Locale_Dir%\locale
;DirMove=%GTK_Locale_Dir%\locale_it|%GTK_Locale_Dir%\locale
[StringReplace=$Bin$\$AppName$\bin\solfege]
os.path.normpath|))=(os.path.join(prefix, "$Lib$\GTK"
[RunAfter]
DirCopy=@AppDataDir@\GNU Solfege|%SettingsDir%|o
DirRemove=@AppDataDir@\GNU Solfege
DirMove=@AppDataDir@\GNU Solfege_backup|@AppDataDir@\GNU Solfege
DirCopy=@MyDocumentsDir@\GNU Solfege\lessonfiles|%LessonFilesDir%|o
DirRemove=@MyDocumentsDir@\GNU Solfege
DirMove=@MyDocumentsDir@\GNU Solfege_backup|@MyDocumentsDir@\GNU Solfege
[Options]
DeleteTemp=true
MultipleIstances=false
ShowSplash=true
WriteLog=false
[SplashScreen]
Image=
Title=
TimeOut=1500
[ Edited Sun 04 May 2008 - 17:41 ] |
