[Spostato] [Backup] Cobian Backup 8.4.0.198 'Black Moon' |
UncleDan |
Registered Member #4764 Joined: Sat 19 May 2007 - 19:39Location: Bologna, Italy Posts: 125 | Nome del software: Cobian Backup 8 'Black Moon' Direct Link al download: -Link- Dimensione File: 8.474.112 byte Nome autore: Luis Cobian eMail autore: Sito Web Autore: -Link- Descrizione: Cobian Backup is a multi-threaded program that can be used to schedule and backup your files and directories from their original location to other directories/drives in the same computer or other computer in your network. FTP backup is also supported in both directions (download and upload). Cobian Backup exists in two different versions: application and service. The program uses very few resources and can be running on the background on your system, checking your backup schedule and executing your backups when necessary. Cobian Backup is not an usual backup application: it only copies your files and folders in original or compressed mode to other destination, creating a security copy as a result. So Cobian Backup can be better described as a "Scheduler for security copies". Cobian Backup supports several methods of compression and strong encryption. Portable tips how-to: Installare in modalità applicazione / Nessun autostart; copiare l'intero contenuto della cartella "Cobian Backup" (di solito in C:\Programmi) e poi disinstallare l'applicazione. Versione: 8.4.0.198 Licenza: Mozilla Public License 1.1 (MPL 1.1) Note: E' uscita da un po' la versione 9 'Amanita', ma è "solo" freeware. cobianbackup8_regshot.zip [ Edited Fri 05 Nov 2010 - 21:17 ] | ||
UncleDan |
Registered Member #4764 Joined: Sat 19 May 2007 - 19:39Location: Bologna, Italy Posts: 125 | NON PORTABILE! Ha un paio di percorsi assoluti negli ini. Peccato, è il software di backup preferito... Scusate la falsa segnalazione e spostate pure altrove. | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Spostato. Lo sviluppo della versione su SourceForge è abbandonato; si potrebbe creare comunuqe un X-ini per la versione opensource, ma la licenza "mozilla" non ho ancora capito che implicazioni ha, e cioè se si può intervenire senza problemi o se va usato lo stesso metodo di Firefox (setup guidato della versione installer originale). Ciao | ||
