Aggiornamento: X-Notepad++ (Aspell) Go to page >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Notepad++ (Aspell) 4.9.2 Link WinPenPack Aggiornamento dalla versione 4.9.1 alla 4.9.2 Home: -Link- Direct Link: -Link- Language: Italiano [ Edited Tue 13 May 2008 - 22:54 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Notepad++ (Aspell) 5.0 Link WinPenPack Aggiornamento dalla versione 5.0 beta alla 5.0 Home: -Link- Direct Link: -Link- Language: Italiano [ Edited Tue 08 Jul 2008 - 19:30 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Notepad++ (Aspell) 5.0.1 Link WinPenPack Aggiornamento dalla versione 5.0 alla 5.0.1 Home: -Link- Direct Link: -Link- Language: Italiano [ Edited Tue 22 Jul 2008 - 22:44 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Notepad++ (Aspell) 5.0.2 Link WinPenPack Aggiornamento dalla versione 5.1 alla 5.0.2 Home: -Link- Direct Link: -Link- Language: Italiano [ Edited Fri 01 Aug 2008 - 14:51 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | Rcs scrisse... X-Notepad++ (Aspell) 5.2 Aggiornamento dalla versione 5.1 alla 5.2 la versione corretta è la 5.02. | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Ciao rbon e grazie per la correzione. | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Notepad++ (Aspell) 5.0.3 Link WinPenPack: -Link- Aggiornamento dalla versione 5.0.2 alla 5.0.3 Home: -Link- Direct Link: -Link- Language: italiano [ Edited Tue 05 Aug 2008 - 23:28 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Notepad++ (Aspell) 5.1 Link WinPenPack: -Link- Aggiornamento dalla versione 5.0.3 alla 5.1 Home: -Link- Direct Link: -Link- Language: italiano -Link- [ Edited Sun 02 Nov 2008 - 20:50 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Il pacchetto di quest'ultima versione contiene (per la prima volta) due versioni distinte, ansi e unicode: But the most important added feature is make Notepad++ version 5.1 a true Unicode-compliant application : Not only you can open a Unicode path file in Notepad++, but also you can use whichever localization file (nativeLang.xml) under whichever language environment (for w2k/xp/vista). SpellChecker.dll (plugin ANSI) non è compatibile con la versione Unicode. Inoltre ho notato che Notepad++ non scrive assolutamente nel registro. A questo punto non saprei che fare... ---- edit ------ Forse la cosa migliore è questa: x-notepad_launcher_1.3_rev7.zip
[ Edited Sat 01 Nov 2008 - 01:10 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | Danix scrisse.... E' vero. SpellChecker.dll (plugin ANSI) non è compatibile con la versione Unicode In effetti è successo un putiferio: gli utenti hanno chiesto l'upgrade dei plugin dalla versione ANSI all versione Unicode. Nel forum hanno risposto, in sostanza, di non ritornare alla versione 5.0.3 ma di aspettare (fiduciosamente) che vengano aggiornati i plugin alla versione Unicode. Jens Lorenz (creatore di SpellChecker) ha risposto così Forum -Link- By: Jens Lorenz (jenslorenz) - 2008-10-31 07:42 New version of following plugins will be released in mid of November by me: Plugin: Current State: Fixes: New Features: Explorer.dll 100% ported Yes Yes WindowManager.dll 100% ported No Yes NativeLang.dll 100% ported No No HexEditor.dll porting started Yes Yes SpellChecker.dll porting not started No No I release all plugins together if SpellChecker finally ported. Best Regards Staremo a vedere. rbon | ||
