The Coccinella
Peter G
Sat 09 Aug 2008 - 20:19
Registered Member #5718
I have found an interesting Instant Messaging Application
"The Coccinella", to be found here: -Link- (//coccinella.im)
It's under GNU GPL and is designed for Jabber and including a "whiteboard".
Maybe it's possible to bring that into a X-Package ?
Mon 11 Aug 2008 - 15:28
Peter G wrote ...
Mmmmmhhhhh
let me see.....
[ Edited Mon 11 Aug 2008 - 15:29 ]
Mon 11 Aug 2008 - 20:58
AAAARRRRGGGGHHHH
It's a nightmare!!!!
Lots of registry voices (HKLM\classes, HKCU\Software\Microsoft), files in Appdata\Microsoft etc...
Anyway, try this launcher:
x-coccinella_beta.zip
How to:
unpack the X-Coccinella_beta.zip and put the "Coccinella Messenger-0.96.8.exe" binary (from the website) on the "X-Coccinella\Bin" folder.
Attention, there is a bug:
the launcher cannot export the "HKLM\Software\Classes\im" voice, maybe because the name is shorter than 3 char...
Please, test it if you can, possibly using regshot...
Thank you
Cheers
[ Edited Mon 11 Aug 2008 - 21:01 ]
justsky
Tue 12 Aug 2008 - 06:55
Registered Member #12361
I just want to say that it is wonderful that you are working with this app. An open source somewhat universal IM with whiteboard that conferences and works well with slow connections. Great addition.
Tue 12 Aug 2008 - 09:55
Hi justsky,
this is only a "first and rough" attempt to create a portable version of Coccinella, needing tests and revision...
Cheers
Tue 12 Aug 2008 - 14:34
New beta launcher :
bug Fix for registry exportations.
x-coccinella_beta_2.zip
As described before, put the Coccinella binary on the "\Bin\Coccinella" folder.
Test needed, as usual.....
Bye
