Aggiornamento: X-Tor Go to page << |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Tor 0.2.3.25-0.2.21 (Windows 7, Vista, and XP) Link winPenPack Aggiornamento dalla versione 0.2.3.25-0.2.21 alla 0.2.3.25-0.2.21-2 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Tor 0.2.4.19-0.2.21 (Windows 8, 7, Vista, and XP) Link winPenPack Aggiornamento dalla versione 0.2.3.25-0.2.21-2 alla 0.2.4.19-0.2.21 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Tor 0.2.4.20-0.2.21 (Windows 8, 7, Vista, and XP) Link winPenPack Aggiornamento dalla versione 0.2.4.19-0.2.21 alla 0.2.4.20-0.2.21 Home: -Link- Direct link: -Link- | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Tor 0.2.4.21-0.2.21 (Windows 8, 7, Vista, and XP) Link winPenPack -Link- Aggiornamento dalla versione 0.2.4.20-0.2.21 alla 0.2.4.21-0.2.21 Home: -Link- Download page: -Link- Direct link Vidalia Exit Bundle: -Link- Firefox addons per la sicurezza online: 1. evitare di scaricare Torbutton 2. scaricare invece NoScript -Link- NoScript v. 2.6.8.19 - Friendly Security direct download: -Link- | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Tor 0.2.4.22-0.2.21 (Windows 8, 7, Vista, and XP) Link winPenPack -Link- Aggiornamento dalla versione 0.2.4.21-0.2.21 alla 0.2.4.22-0.2.21 Home: -Link- Index of /dist/vidalia-bundles (download page): -Link- Direct download link Vidalia Exit Bundle: -Link- Note -> Info from Download page vidalia-exit-bundle-0.2.4.22-0.2.21.exe 20-May-2014 01:13 8.9M | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Tor 0.2.4.22-0.2.21-1 (Windows 8, 7, Vista, and XP) Link winPenPack -Link- Aggiornamento dalla versione 0.2.4.22-0.2.21 alla 0.2.4.22-0.2.21-1 Home: -Link- Index of /dist/vidalia-bundles (download page): -Link- Direct download link Vidalia Exit Bundle: -Link- Download Tips quando si accede alla download page di Vidalia sul server torproject.org premere il bottone Last modified in modo da selezionare i programmi per data (più recenti in basso). | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Tor 0.2.4.23-0.2.21 (Windows 8, 7, Vista, and XP) Link winPenPack -Link- Aggiornamento dalla versione 0.2.4.22-0.2.21-1 alla 0.2.4.23-0.2.21 Home: -Link- Index of /dist/vidalia-bundles (download page): -Link- Direct download link Vidalia Exit Bundle: -Link- Download Tips quando si accede alla download page di Vidalia sul server torproject.org premere il bottone Last modified in modo da selezionare i programmi per data (più recenti in basso). | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Tor 0.4.2.6 Stable Link winPenPack -Link- Home: -Link- Tor Blog: -Link- Repository di Tor: -Link- Direct download Tor 0.4.2.6 per Win32: -Link- Direct download Tor 0.4.2.6 per win64: -Link- Le versioni Alpha di Tor si trovano nella directory 9.5a6: - Repository: -Link- - Tor 0.4.3.2 Alpha per Win32: -Link- - tor 0.4.3.2 Alpha per Win64: -Link- Nota: Tor è componente essenziale di TorBrowser e si trova nella directory di quest'ultimo: --> di seguito indico il percorso completo alla versione stabile di Tor 0.4.2.6. - Repository: -Link- - TorBrowser: -Link- - TorBrowser 9.0.5: -Link- Usare X-Tor con X-Chromium ricordare che: 1. X-Tor va sempre lanciato per primo 2. quando compare il messaggio '... Bootstrapped 100% <done>: Done' abbassare la finestra (X-Tor deve rimanere in esecuzione) 3. lanciare X-Chromium, ma solo dopo avere modificato il file X-Chromium.ini, aggiungendo sulla riga di --> Parameters ---> alla fine della riga -----> ; --proxy-server="socks5://localhost:9050" --host-resolver-rules="MAP * 0.0.0.0 , EXCLUDE localhost" (il ; al termine del comando precedente non è necessario ma serve visivamente a separare il nuovo comando aggiunto) 4. al termine della navigazione chiudere prima X-Chromium e poi X-Tor. Ricordare che X-Launcher (X-Chromium.ini) NON accetta più di una riga del comando Parameters, ma la riga può essere molto lunga (32 K, credo). Il riferimento tecnico del comando aggiunto a X-Chromium.ini si può trovare nella seguente discussione di The Chromium Project: --> Configuring a SOCKS proxy server in Chrome: -Link- x-chromium_ini_with_tor.rar | ||
Go to page <<
