[Suite agenda, email, chat] Spicebird Go to page >> |
Moticanus |
Registered Member #4618 Joined: Thu 10 May 2007 - 08:29Location: Modica Posts: 1352 | Nome del software: Spicebird Direct Link al download - installer: -Link- Direct Link al download - zip: -Link- Link al Language pack italiano: -Link- Dimensione File: 10.485.760 (10MB) installer - 14.889.779 (14,2MB) Zip Nome autore: synovel.com eMail autore: Sito Web Autore: -Link- ( -Link- ) Descrizione: Spicebird è una suite collaborativa open-source, per gestire contatti ed email via POP/IMAP, feed RSS e chat. È anche PIM per la gestione del calendario e delle attività ed è possibile sottoscrivere i calendari di altri utenti. Portable tips how-to: n/a Versione: 0.7 Beta Licenza: Core Spicebird source code is licensed under a disjunctive tri-license giving you the choice of one of the three following sets of free software/open source licensing terms: GPL 2, LGPL 2.1, MPL. Spicebird binaries are currently licensed under the GPL version 2 or later. Info originali: Spicebird is a collaboration client that provides integrated access to email, contacts, calendaring and instant messaging in a single application. It provides easy access to various web services while retaining all the advantages of a desktop application. The application is based on projects likeThunderbird, Lightning and Telepathy and adds more functionality and integration among its components. This release of Spicebird adds the following functionality:
[ Edited Fri 05 Nov 2010 - 22:16 ] | ||
Moticanus |
Registered Member #4618 Joined: Thu 10 May 2007 - 08:29Location: Modica Posts: 1352 | Il software si avvia normalmente estraendo i file contenuti inspicebird-beta-0.7.en-US.win32.zip ed avviando l'eseguibile Spicebird.exe ( -Link- ). Ha scritto nella cartella: C:\Documents and Settings\home_virtual\Dati applicazioni\Spicebird\Profiles\2wex73pl.default\Mail\in.email.it perchè nel menu Account settings è impostata come Local directory. Non proprio portatile. ___________________ log_spicebird.txt.zip | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Moticanus wrote ... Ha scritto nella cartella: C:\Documents and Settings\home_virtual\Dati applicazioni\Spicebird\Profiles\2wex73pl.default\Mail\in.email.it Non è solo quello il problema: il programma usa la struttura/motore Mozilla, quindi agendo opportunamente si può dirottare la scrittura del profilo in User\Spacebird; restano però da "sterilizzare" tutte le voci che Mozilla gestisce. Tanto per darti un'idea bisogna creare una portabilizzazione stile Firefox, non proprio una passeggiata.... Inoltre le lingue aggiuntive sono esterne, da inserire tramite una installazione stile estensione xpi. | ||
Moticanus |
Registered Member #4618 Joined: Thu 10 May 2007 - 08:29Location: Modica Posts: 1352 | Beh in effetti non apporterebbe niente di nuovo al parco macchine di wpp. E' solo che riunisce in se diverse funzioni che al momento vengono svolte da più applicazioni! | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Sto provando a portabilizzarlo, ma le voci da trattare sono un bel po': essendo un insieme di programmi, al momento ho trovato voci per il browser, per la mail, percorsi assoluti sparati in giro, e non ho ancora verificato le funzioni di blog, rss ecc.. Inoltre, grave problema, nella versione portabile non sono riuscito a fargli digerire le lingue diverse da quella di default: l'installazione funziona, il plugin è visibile, ma non si attivano... | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | ** Cercasi tester volontario ** X-Spicebird è in versione beta (la beta della "beta"), ma servirebbe qualche tester che verifichi ad ampio raggio (e abbastanza a fondo) le diverse funzionalità del programma per mail/blog/rss/chat ecc... Dovrei essere riuscito a intercettare le voci per mail e news rss, ma molte altre funzioni non riesco a verificarle, anche a causa del firewall aziendale che mi blocca gli accessi. Se qualcuno è disponibile lasci la propria "candidatura", provvederò poi a fornire direttamente il link per la versione di TEST, che come comprensibile non è ancora in download. [ Edited Wed 14 Jan 2009 - 17:22 ] | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | Eccoti un "kamikaze part-time". PS: RSS feeds non li uso molto, ma per il resto mi sento abbastanza "ferrato". | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Primo problema: il file "panacea.dat" presente in user\profile contiene percorsi assoluti ed è necessario al programma per funzionare correttamente, non può essere quindi eliminato impunemente dal launcher ad ogni avvio. La struttura interna però è molto particolare, i percorsi sono spezzati su più righe, come si può vedere dall'esempio che allego: panacea.dat
// <!-- <mdb:mork:z v="1.4"/> -->< <(a=c)> // (f=iso-8859-1)
al momento l'unica soluzione che ho trovato è questa:
[StringReplace=%SPICEBIRD_PROFILE%\panacea.dat]
oppure versione un po' più ridotta:
Il problema è che se il percorso è troppo lungo, non si riesce a identificare correttamente il percorso e addio portabilizzazione; inoltre se il programma non riesce a leggere correttamente il file, va in crash. | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | =D:\\Svil\\Spicebird\\X-Spicebird_beta_0.7_TEST\\User\\Spicebird\\Profiles\ \\Default\\Mail\\Local Folders)(89=c)(8A=ffffffff)(8B=)(8C=Local Folders) Perchè dopo Profiles\ va a capo ed inserisce una doppia barra rovesciata? Non c'è modo di correggerlo? =| Certo che far partire il replace da = non è che sia proprio una sicurezza...ma mi sa che non c'è altra soluzione. ---edit----- Dato che ci sei, varrebbe la pena verificare quanto queste istruzioni presenti "anticamente" nel launcher per Thunderbird, e poi eliminate perchè davano problemi, siano necessarie:
E quanto queste (ancora presenti) debbano rimanere:
[WriteToReg=%MOZ_DEFAULT_REG%]
[ Edited Thu 15 Jan 2009 - 13:43 ] | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Danix wrote ... Perchè dopo Profiles\ va a capo ed inserisce una doppia barra rovesciata? Non c'è modo di correggerlo? E' il programma stesso che lo scrive in quel modo; questo è un esempio di come verrebbe scritto con un percorso pìù corto:
=D:\\Z\\X-Spicebird\\User\\Spicebird\\Profiles\\Default\\ImapMail\\imap.gm\
la barra singola credo venga inserita per riconoscere la continuazione dei dati nella riga successiva. =| Certo che far partire il replace da = non è che sia proprio una sicurezza...ma mi sa che non c'è altra soluzione. Visto che la riga inizia con quattro spazi, si può modificare (meglio di niente) in questo modo:
Resta sempre il problema che se il percorso è troppo lungo, e quindi la stringa "\\User\\" va a capo o viene spezzata, StringReplace non riese a lavorare; mi sa comunque che non c'è altra soluzione. | ||
