Aggiornamento: X-7Zip Go to page << >> |
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1684 | X-7zip 4.65 Link winpenPack Aggiornamento dalla versione 4.64 alla 4.65 Home: -Link- Direct Link: (non portatile) -Link- [ Edited Sat 07 Feb 2009 - 19:47 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-7zip 9.04 beta Link winpenPack Aggiornamento dalla versione 4.65 alla 9.04 beta Home: -Link- Direct Link: (non portatile) -Link- [ Edited Thu 29 Apr 2010 - 17:38 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Rcs wrote ... X-7zip 9.04 beta Link winpenPack Aggiornamento dalla versione 4.65 alla 9.04 beta Home: -Link- Direct Link: (non portatile) -Link- Don't use this beta version for important data. Call "Test" command after each compressing operation. -Link- Direi di non aggiornare. | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | X-7zip 9.13 beta Link winpenPack Aggiornamento dalla versione 4.65 alla 9.13 beta Home: -Link- Direct Link: (non portatile) -Link- >>> Software in Beta release - Aggiornamenti sospesi <<< Per ogni evenienza: il launcher della versione 4.65 è compatibile con la versione 9.13 beta. | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | X-7zip 9.14 beta Link winpenPack Aggiornamento dalla versione 4.65 alla 9.14 beta Home: -Link- Direct Link: (not portable) -Link- --- edit zandet2 --- software wpp rilasciato con nota per versione alternativa stabile [ Edited Tue 08 Jun 2010 - 12:57 ] | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | X-7zip 9.16 beta Link winpenPack Aggiornamento dalla versione 9.14 alla 9.16 beta Home: -Link- Direct Link: (not portable) -Link- software wpp aggiornato | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | X-7zip 9.17 beta Link winpenPack Aggiornamento dalla versione 9.16 alla 9.17 beta Home: -Link- Direct Link: (not portable) -Link- --- edit zandet2 --- software wpp aggiornato con launcher 1.4.2 [ Edited Wed 20 Oct 2010 - 14:44 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-7zip 9.18 beta Link winpenPack Aggiornamento dalla versione 9.17 beta alla 9.18 beta Home: -Link- Direct Link: (not portable) -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Thu 11 Nov 2010 - 23:38 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-7zip 9.19 beta Link winpenPack Aggiornamento dalla versione 9.18 beta alla 9.19 beta Home: -Link- Direct Link: (not portable) -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Fri 12 Nov 2010 - 13:32 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-7zip 9.20 Link winpenPack Aggiornamento dalla versione 9.19 beta alla 9.20 Home: -Link- Direct Link: (not portable) -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Fri 19 Nov 2010 - 17:09 ] | ||
