Open Office Fonts
fcarson
Wed 23 Sep 2009 - 21:48
Registered Member #35890
How do I add fonts to Portable Open Office Impress?
I'm using Portable Impress for presentations via several PCs that are not mine. The fonts I want to use are not installed on these PCs. Am I stuck with the core fonts that are in stalled in Impress? Or is there a way to add fonts to the portable environment and not the host PC?
Thanks for your assistance.
Thu 24 Sep 2009 - 09:24
Registered Member #74
Hi fcarson,
as I know, at this moment OpenOffice.org uses only the fonts installed in the host PC.
You could try a couple of tricks:
1) Use FontOOo -Link- and see if it works as they declare ("FontOOo only installs fonts for OpenOffice.org and doesn't perform any OS level font installation."). I don't know if this is possible also for portable version, but you can try...
2) Embed fonts into the document, saving in PDF hybrid format, as you can see here: -Link-
Hope it helps...
Best Regards
