Aggiornamento: NVDA Go to page >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | NVDA 2009.1 portable version Link winPenPack Aggiornamento dalla versione 0.6p3.2 alla 2009.1 Home: -Link- Direct link: -Link- Risultato test: | ||
Moticanus |
Registered Member #4618 Joined: Thu 10 May 2007 - 08:29Location: Modica Posts: 1352 | Rcs wrote ... NVDA 2009.1 portable version Link winPenPack Aggiornamento dalla versione 0.6p3.2 alla 2009.1 Home: -Link- Direct link: -Link- Risultato test: nulla da segnalare log_nvda.zip | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | NVDA 2010.1 portable version Link winPenPack Aggiornamento dalla versione 2009.1 alla 2010.1 portable version Home: -Link- Direct link: -Link- Risultato test: niente da segnalare [ Edited Thu 01 Apr 2010 - 22:06 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | NVDA 2010.2 portable version Link winPenPack Aggiornamento dalla versione 2010.1 alla 2010.2 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare [ Edited Fri 29 Oct 2010 - 22:20 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | NVDA 2011.1 portable version Link winPenPack Aggiornamento dalla versione 2010.2 alla 2011.1 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare [ Edited Mon 07 Mar 2011 - 21:12 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | NVDA 2011.1.1 Link winPenPack Aggiornamento dalla versione 2011.1 alla 2011.1.1 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare [ Edited Sat 09 Apr 2011 - 21:21 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | NVDA 2011.2 Link winPenPack Aggiornamento dalla versione 2011.1.1 alla 2011.2 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare [ Edited Wed 07 Sep 2011 - 01:30 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | NVDA 2011.3 Link winPenPack Aggiornamento dalla versione 2011.1.1 alla 2011.2 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare [ Edited Sat 26 Nov 2011 - 16:57 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | NVDA 2012.1 Link winPenPack Aggiornamento dalla versione 2011.2 alla 2012.1 Home: -Link- Direct link: -Link- Risultato test: niente da segnalare [ Edited Fri 23 Mar 2012 - 15:36 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | NVDA 2012.2.1 Link winPenPack Aggiornamento dalla versione 2012.1 alla 2012.2.1 Home: -Link- Direct link: -Link- --- edit zandet2 --- Risultato test: niente da segnalare aggiornato scheda di download riportando le istruzioni per ottenere la versione portabile [ Edited Mon 18 Jun 2012 - 11:13 ] | ||
