Aggiornamento: X-CdrTools FrontEnd Go to page >> |
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | CdrTools FrontEnd 1.3 Pre2 Aggiornamento dalla versione 1.3 Pre1 alla 1.3 Pre2 Home: -Link- Direct Link: -Link- [ Edited Mon 08 Sep 2008 - 23:08 ] | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | CdrTools FrontEnd 1.3 Aggiornamento dalla versione 1.3 Pre2 alla 1.3 Home: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | CdrTools FrontEnd 1.3.1 Aggiornamento dalla versione 1.3 alla 1.3.1 Home: -Link- Direct Link: -Link- Risultato test: Chiave aggiunta:8 ---------------------------------- HKLM\SOFTWARE\Cygnus Solutions HKLM\SOFTWARE\Cygnus Solutions\Cygwin HKLM\SOFTWARE\Cygnus Solutions\Cygwin\mounts v2 HKLM\SOFTWARE\Cygnus Solutions\Cygwin\Program Options HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Cygnus Solutions HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Cygnus Solutions\Cygwin HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Cygnus Solutions\Cygwin\mounts v2 HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Cygnus Solutions\Cygwin\Program Options [ Edited Tue 25 Mar 2008 - 21:37 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | CdrTools FrontEnd 1.3.2 Link winPenPack Aggiornamento dalla versione 1.3.1 alla 1.3.2 Home: -Link- Direct Link: -Link- Risultato test: Chiave aggiunta:8 ---------------------------------- HKLM\SOFTWARE\Cygnus Solutions HKLM\SOFTWARE\Cygnus Solutions\Cygwin HKLM\SOFTWARE\Cygnus Solutions\Cygwin\mounts v2 HKLM\SOFTWARE\Cygnus Solutions\Cygwin\Program Options HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Cygnus Solutions HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Cygnus Solutions\Cygwin HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Cygnus Solutions\Cygwin\mounts v2 HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Cygnus Solutions\Cygwin\Program Options [ Edited Mon 08 Sep 2008 - 16:43 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Rcs wrote ... Risultato test: Chiave aggiunta:8 ---------------------------------- HKLM\SOFTWARE\Cygnus Solutions HKLM\SOFTWARE\Cygnus Solutions\Cygwin HKLM\SOFTWARE\Cygnus Solutions\Cygwin\mounts v2 HKLM\SOFTWARE\Cygnus Solutions\Cygwin\Program Options HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Cygnus Solutions HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Cygnus Solutions\Cygwin HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Cygnus Solutions\Cygwin\mounts v2 HKU\S-1-5-21-2669182307-3225018408-52446104-1004\Software\Cygnus Solutions\Cygwin\Program Options Inoltre, vengono scritti alcuni percorsi assoluti (non aggiornabili) nel file di configurazione cdrtfe.ini Viene impostata di default questa cartella: I file temporanei vengono salvati nella directory di sistema %TEMP% (e presumibilmente non vengono cancellati alla chiusura del programma): ----------------------------------------------------------------------------- Per questi motivi d'ora in poi verrà distribuito come X-Version. X-CdrTools FrontEnd -Link- ----------------------------------------------------------------------------- [ Edited Mon 08 Sep 2008 - 23:08 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-CdrTools FrontEnd 1.3.3 Link winPenPack Aggiornamento dalla versione 1.3.2 alla 1.3.3 Home: -Link- Direct Link: -Link- [ Edited Fri 05 Dec 2008 - 21:34 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-CdrTools FrontEnd 1.3.4 Link winPenPack Aggiornamento dalla versione 1.3.3 alla 1.3.4 Home: -Link- Direct Link: -Link- ==EDIT zandet2== software wpp aggiornato [ Edited Sat 03 Jan 2009 - 12:05 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-CdrTools FrontEnd 1.3.5 Link winPenPack Aggiornamento dalla versione 1.3.4 alla 1.3.5 Home: -Link- Direct Link: -Link- [ Edited Fri 10 Apr 2009 - 15:39 ] | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | X-CdrTools FrontEnd 1.3.6 Link winPenPack Aggiornamento dalla versione 1.3.5 alla 1.3.6 Home: -Link- Direct Link: -Link- [ Edited Sat 09 Jan 2010 - 15:11 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-CdrTools FrontEnd 1.3.7 Link winPenPack Aggiornamento dalla versione 1.3.6 alla 1.3.7 Home: -Link- Direct Link: -Link- | ||
