Aggiornamento: X-IronGo to page << >> |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Iron 9.0.600.2 Link winPenPack Aggiornamento dalla versione 9.0.600.1 alla 9.0.600.2 Home: -Link- ![]() Direct link: -Link- ![]() | ||
| Taf |
![]() ![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 2771 ![]() | X-Iron 10.0.650.0 Link winPenPack Aggiornamento dalla versione 9.0.600.2 alla 10.0.650.0 Home: -Link- ![]() Direct link: -Link- ![]() NOTA by taf: testato con vecchio launcher. su win7 64bit no UAC - Tutto OK! | ||
| Bourne |
![]() ![]() Registered Member #4287 Joined: Fri 20 Apr 2007 - 16:55Posts: 536 ![]() | Taf wrote ... NOTA by taf: testato con vecchio launcher. su win7 64bit no UAC - Tutto OK! Confermo (win7 pro 32bit, account standard, UAC attivo) | ||
| Taf |
![]() ![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 2771 ![]() | X-Iron 10.0.650.1 Link winPenPack Aggiornamento dalla versione 10.0.650.0 alla 10.0.650.1 Home: -Link- ![]() Direct link: -Link- ![]() NOTA by taf: testato con vecchio launcher. su win7 64bit no UAC - Tutto OK! - si può aggiornare il "pack" | ||
| Bourne |
![]() ![]() Registered Member #4287 Joined: Fri 20 Apr 2007 - 16:55Posts: 536 ![]() | Taf wrote ... X-Iron 10.0.650.1 testato con vecchio launcher. su win7 64bit no UAC - Tutto OK! - si può aggiornare il "pack" Ariconfermo (win7 pro 32bit, account standard, UAC attivo) | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Iron 11.0.700.1 Link winPenPack Aggiornamento dalla versione 10.0.650.1 alla 11.0.700.1 Home: -Link- ![]() Direct link: -Link- ![]() ---EDIT--- NOTA by taf: testato con vecchio launcher. su win7 64bit no UAC - Tutto OK! - si può aggiornare il "pack" [ Edited Wed 04 May 2011 - 16:04 ] | ||
| Taf |
![]() ![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 2771 ![]() | testato! si può aggiornare tranquillamente! ...così magari arriviamo prima della "concorrenza" .... -Link- ![]() [ Edited Thu 05 May 2011 - 18:39 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 8962 ![]() | X-Iron 11.0.700.2 Link winPenPack Aggiornamento dalla versione 11.0.700.1 alla 11.0.700.2 Home: -Link- ![]() Direct link: -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Fri 06 May 2011 - 23:57 ] | ||
| Taf |
![]() ![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 2771 ![]() | X-Iron 11.0.700.3 Link winPenPack Aggiornamento dalla versione 11.0.700.2 alla 11.0.700.3 Home: -Link- ![]() Direct link: -Link- ![]() PS: test effettuato con vecchio launcher: niente da segnalare. aggiornare --- edit zandet2 --- software wpp aggiornato alla release 87001 [ Edited Thu 02 Jun 2011 - 19:07 ] | ||
| Bourne |
![]() ![]() Registered Member #4287 Joined: Fri 20 Apr 2007 - 16:55Posts: 536 ![]() | Taf wrote ... X-Iron 11.0.700.3 Link winPenPack Aggiornamento dalla versione 11.0.700.2 alla 11.0.700.3 Dato che ci siete aggiornate alla Build 87001... | ||
