X-MediaPlayerClassic launcher Go to page >> |
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Grazie alla segnalazione di bagr mi sono accorto che Media Player Classic salva la Playlist in %APPDATA%. Versione portatile da testare, sperando che non siano solo gli stranieri a testarla oltre che a segnalare i bugs - scusate la doverosa frecciatina - Thank you bagr! X-Launcher Ini for test: (inserire il player in una cartella chiamata "Media Player Classic")
[ Edited Fri 23 May 2008 - 23:32 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | @bagr: look for the "SnapShotPath" But, can Media Player Classic save snapshot?? How? | ||
bagr |
Registered Member #4759 Joined: Sat 19 May 2007 - 09:25Posts: 15 | Thank you Danix that you made *.ini file so quick. I think that MPC can save snapshot (Images) Play some video file (File -> Save Image... / Save Thumbnails...) MPC can even record ( Open device (TV tuner) and then View -> Capture) I tested .ini file and didn't find any problems. | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1679 | Danix wrote ... @bagr: look for the "SnapShotPath" But, can Media Player Classic save snapshot?? How? I haven't tested it but I think you should use one of these File menu options: File - Save Image... or File - Save Thumbnails... Just try. | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | There is a bug... I'll correct this.... | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Ok! Now the program saves thumbnails in the "default" folder. Sorry but I can't create only one folder for settings, but three... I'm going to try it..
[ Edited Sun 03 Jun 2007 - 18:27 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | This is the last INI. Now, ONLY ONE Media Player Classic folder FOR settings is created: (please, test it )
[ Edited Sun 03 Jun 2007 - 18:50 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Media Player Classic [rev2] Alcune chiavi di registro in HKEY_LOCAL_MACHINE mi sono sfuggite... Inoltre, dato che il programma offre la possibilità di salvare le opzioni in un file INI all'interno della propria cartella, bisogna prevedere il percorso per i thumbnails anche in questo caso: INI:
Attenzione: notare la parte seguente (già impostata per la versione italiana)
[WriteToIni=$ExeDir$\mplayerc.ini]
Da impostare a seconda che si utilizzi la versione italiana o inglese del software. [ Edited Tue 31 Jul 2007 - 01:58 ] | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | il mio test con questo ultimo INI mi dice: ERROR: ....lamiapathdiwpp/bin/MyApp/.... NOT FOUND! perchè vuole che la cartella "Media Player Classic" sia "MyApp"?? se cerco nell'ini... tale sintassi non la trovo... (sarò utOnto...ma è così! ) [ Edited Tue 31 Jul 2007 - 08:32 ] | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | COME NON DETTO! il problema mi si presenta SOLO se COPIO/INCOLLO l'ini qui presente. Ho scaricato la versione "ufficiale" da qui: -Link- e tutto è tornato a posto... comunque sarei curioso di sapere il perchè... [ Edited Tue 31 Jul 2007 - 09:43 ] | ||
