[Moved] Useful parameter for X-Chromium
JackL
Sat 19 Jun 2010 - 18:35
Registered Member #6127
Hi Guys!
As per Danix suggestion, I open new thread for this topic.
Maybe someone could help with development of X-Chromium launcher.
I found the parameters that have to be executed with exe shortcut for chromium to enable build-in flashplayer, as per tutorial :
"to use the bundled Flash Player plug-in, add --enable-internal-flash to your command line or shortcut for starting Google Chrome"
additional useful parameters is:
--enable-sync-extensions
will enable syncing extensions with your google account
all the best
J
