X-Firefox 3.66 plugin. Thanks. |
dlusera |
Registered Member #39104 Joined: Fri 09 Jul 2010 - 12:38Posts: 37 | I want to install Portable plugin on X-Firefox. I not want install to my computer. how can do it ? such as, 1.Java 2.Flash 3.Rmvb , real audio, real movie. Any ideal make portable plugin ? Thanks. | ||
JCL |
Registered Member #39110 Joined: Sat 10 Jul 2010 - 12:54Location: Vienna, Austria Posts: 20 | Hi - something in this directon ... I tryed to install a plugin on firefox ( flash player - or something like that ) on my Memory-Stick and the reply was " can't install because there is a newer version already installed in the system " --> means win7. hope someone has a hint ? [ Edited Thu 15 Jul 2010 - 11:39 ] | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | Hi dlusera, hi JCL, this question has been already answered (in italian forum only, sorry... ) In a few words: is enough to copy the plugins under "Lib\Mozilla\Plugins" folder. Here there are some plugins installable is a such manner: - np32dsw.dll (shockwave director) - NPSWF32.dll (shockwave flash - need also ShockwavePlugin.class file) - nppdf32.dll (adobe acrobat) - np-mswmp.dll (Microsoft® Windows Media Player Firefox Plugin) - npjp2.dll (JPEG2000 image viewer) As you can see here -Link- from rev13, X-Firefox can use Java "portable" in $Lib\Java folder (see packs structure for more informations) Here -Link- -Link- there are also some useful links that depict in details this task (for Flash only), but I think that could be extended with minor differences also to the others. Hope this helps. Best Regards ZioZione | ||
dlusera |
Registered Member #39104 Joined: Fri 09 Jul 2010 - 12:38Posts: 37 | Where can I download this following portabe plugin ? Thanks. - np32dsw.dll (shockwave director) - NPSWF32.dll (shockwave flash - need also ShockwavePlugin.class file) - nppdf32.dll (adobe acrobat) - np-mswmp.dll (Microsoft® Windows Media Player Firefox Plugin) - npjp2.dll (JPEG2000 image viewer) ================ ZioZione wrote ... Hi dlusera, hi JCL, this question has been already answered (in italian forum only, sorry... ) In a few words: is enough to copy the plugins under "Lib\Mozilla\Plugins" folder. Here there are some plugins installable is a such manner: - np32dsw.dll (shockwave director) - NPSWF32.dll (shockwave flash - need also ShockwavePlugin.class file) - nppdf32.dll (adobe acrobat) - np-mswmp.dll (Microsoft® Windows Media Player Firefox Plugin) - npjp2.dll (JPEG2000 image viewer) As you can see here -Link- from rev13, X-Firefox can use Java "portable" in $Lib\Java folder (see packs structure for more informations) Here -Link- -Link- there are also some useful links that depict in details this task (for Flash only), but I think that could be extended with minor differences also to the others. Hope this helps. Best Regards ZioZione | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | dlusera wrote ... Where can I download this following portabe plugin ? Thanks. - np32dsw.dll (shockwave director) - NPSWF32.dll (shockwave flash - need also ShockwavePlugin.class file) - nppdf32.dll (adobe acrobat) - np-mswmp.dll (Microsoft® Windows Media Player Firefox Plugin) - npjp2.dll (JPEG2000 image viewer) Hi dsusera, the easiest way is to search them separately one by one with google... Best Regards ZioZione | ||
dlusera |
Registered Member #39104 Joined: Fri 09 Jul 2010 - 12:38Posts: 37 | Thanks. But I worry virus and where I got new version ? Can help search for me ? Thanks Again. ZioZione wrote ... dlusera wrote ... Where can I download this following portabe plugin ? Thanks. - np32dsw.dll (shockwave director) - NPSWF32.dll (shockwave flash - need also ShockwavePlugin.class file) - nppdf32.dll (adobe acrobat) - np-mswmp.dll (Microsoft® Windows Media Player Firefox Plugin) - npjp2.dll (JPEG2000 image viewer) Hi dsusera, the easiest way is to search them separately one by one with google... Best Regards ZioZione | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | dlusera wrote ... Thanks. But I worry virus and where I got new version ? Can help search for me ? Thanks Again. This means that you never made a search on Google because you worry viruses? | ||
dlusera |
Registered Member #39104 Joined: Fri 09 Jul 2010 - 12:38Posts: 37 | I already try. 1. I don't wihch version is suitable and news (Many dll file same file name), 2.virus problems. So , I hope has some one can tell me the download site or upload for me. Many Thanks. Danix wrote ... dlusera wrote ... Thanks. But I worry virus and where I got new version ? Can help search for me ? Thanks Again. This means that you never made a search on Google because you worry viruses? | ||
