Links - Win7 - Error
JCL
Sun 01 Aug 2010 - 11:03
Registered Member #39110
hello,
problems arise when dragging a link - from the 64 bit-program-directory - to wpp !
the ( working ) link uses the fallowing reference
"C:\Program Files\Microsoft Games\Mahjong\Mahjong.exe"
that translates wpp to
$Drive\Program Files (x86)\Microsoft Games\Mahjong\Mahjong.exe
don't ask why I use this example
as you see the wrong directory is used
Q: is this a known bug ?
Sun 01 Aug 2010 - 18:19
Registered Member #33962
Hi JCL,
I have started to use seven few days ago, and I have the same problem, that seems extended to all applications at 32bit toward the 64 bit environment.
It seems that it is not possible to do a drag and drop between an application at 64 bit and one at 32 ( It seems! ), while between 32 vs 32 all work fine.
For examlpe, if you try to use x-mnuCommander you should be able to use the files drag and drop functionalities because the program is at 32 bit.
Let me know.
Bye.
--- EDIT ---
sorry JCL, I have misunderstood your message.
I believed that you are speaking about another problem.
I will verify the problem and I will take note of the BUG
[ Edited Sun 01 Aug 2010 - 18:31 ]
JCL
Sun 01 Aug 2010 - 20:35
LordJim60 wrote ...
sorry JCL
no reason to be
if you realy bother to check my post - just take a program-link that points to the 64 bit directory and drop it somewhere onto wPP - you will see ...
have a good time
