Aggiornamento: X-Disk Cleaner |
Ketty |
Registered Member #5089 Joined: Sat 09 Jun 2007 - 02:27Posts: 1461 | Disk Cleaner 1.5.7 -Link- Aggiornamento dalla versione 1.5.7 alla 1.5.7 (Feb 2008) Home: -Link- Direct Link: -Link- Risultato test: Niente da segnalare [ Edited Wed 11 Aug 2010 - 15:04 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Disk Cleaner 1.6.1353 (Vista/7) -Link- Aggiornamento dalla versione 1.5.7 alla 1.6.1353 Home: -Link- Direct Link: -Link- Risultato test: Si richiede test su Vista/7 Note: per Xp rimane valida la versione 1.5.7 | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Disk Cleaner 1.7.1616 (XP/Vista/7) Link winPenPack Aggiornamento dalla versione 1.6.1353 alla 1.7.1616 Home: -Link- Direct Link: -Link- Risultato test: Not portable Cartella aggiunta:1 ---------------------------------- C:\Documents and Settings\Rcs\Dati applicazioni\Disk Cleaner File aggiunto:2 ---------------------------------- C:\Documents and Settings\Rcs\Dati applicazioni\Disk Cleaner\dcsettings.ini [ Edited Wed 11 Aug 2010 - 14:32 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | X-Disk Cleaner 1.8.1795 (XP/Vista/7) Link winPenPack Aggiornamento dalla versione 1.7.1616 alla 1.8.1795 Home: -Link- Direct Link: -Link- | ||
