Aggiornamento: X-Chromium Go to page << >> |
JackL |
Registered Member #6127 Joined: Tue 18 Sep 2007 - 16:36Posts: 68 | Hi there! the newest version of chromium 6.0.426.0 (49004) -Link- works without problem with x-launcher. news for this version is the support for WebM - new HTML5 video codec with V8 and vorbis audio codec inside. for some reason I could not activate build in flash player - the solution for that is : find flashplayer.xpi downlowed and change extention to .zip extract flashplayer.xpt and NPSWF32.dll create folder "plugins" in \X-Chromium_6.0.397.0_build46552_rev10\Bin\Chrome and copy extracted files there and you can enjoy with portable browser with portable flashplayer now :] Ciao a tutti J =============== New topic -Link- =============== [ Edited Sun 20 Jun 2010 - 12:12 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | We are off topic.. This topic (normally) must be used for updates signallings. From now, for questions concerning the development or for ANY OTHER QUESTION other than updates, please open a new topic! In order to facilitate the search in website, should be opened a topic for each question. | ||
gibdemaffen |
Registered Member #38871 Joined: Fri 04 Jun 2010 - 10:31Posts: 27 | --snip-- sorry didn't read this topic is only for updates. i'll open a new thread. (here: -Link- [ Edited Wed 29 Sep 2010 - 07:19 ] | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | X-Chromium 9.0.584.0 build 66139 Link winPenPack Aggiornamento dalla versione 6.0.397.0 build 46552 alla versione 6.0.398.0 Home: -Link- Direct Link: (not portable) -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Mon 15 Nov 2010 - 23:39 ] | ||
phant0mw0rm |
Registered Member #5039 Joined: Wed 06 Jun 2007 - 12:08Posts: 73 | X-Chromium 11.0.666.0 Link alla pagina download winPenPack Aggiornamento dalla versione 9.0.584.0 build 66139 alla versione 11.0.666.0 build 74274 Home Direct Link: (not portable) | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Il link all'ultima versione non è più disponibile -Link- Qualcuno riesce a trovare il server da cui scaricare l'ultima versione? | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Mi da versione 16.0.877.0 (Build 100430 Windows), sarà mica il caso di aggiornare? | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | X-Chromium 16.0.877.0 (Build 100430 Windows) Link winPenPack Aggiornamento dalla versione 12.0.715.0 alla versione 16.0.877.0 (Build 100430) Home: -Link- Direct Link: (not portable) -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Per provare a risolvere questo bug -Link- forse si potrebbe aggiornare. Ma continua a non essere disponibile.. ============== edit =============== forse qui c'è l'ultima -Link- ===================================== [ Edited Thu 29 Sep 2011 - 16:19 ] | ||
