Vote for winPenPack on SourceForge! ![]() winPenPack is competing for "The July 2013 Project of the Month" on SourceForge. To vote is not difficult, is enough to have a Twitter account! [Read more..] Vote now! |
X-PDFsam - converting to English |
| RoninV |
![]() ![]() Registered Member #39398 Joined: Thu 16 Dec 2010 - 19:55Posts: 2 | After installing X-PDFsam on a memory stick, then copying bin/lib java files to the appropriate folder, I started X-PDFsam. The program ran in Italian. According to the X-Software Localization information, to run the program in English, one simply has to... 'overwrite the X-Software.ini file inside the main folder with the one located in the English_users folder, and start X-Software.exe.' This did not work. Using Beyond Compare, I was able to confirm that the English version of the X-PDFsam.ini file, as opposed to the Italian version, is now located in the main folder. Any thoughts or suggestions on how to remedy this issue would be appreciated. Thanks. | ||
| RoninV |
![]() ![]() Registered Member #39398 Joined: Thu 16 Dec 2010 - 19:55Posts: 2 | SOLVED!!! After running X-PDFsam, the user has to go into Settings and change the language selected. Apparently; (1) overwriting the *ini file is not all that is required, or (2) simply changing the language in Settings is all that is required. | ||
