Aggiornamento: Recuva Go to page << |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Recuva 1.50.1036 Link winPenPack Aggiornamento dalla versione 1.49.1019 alla 1.50.1036 Home: -Link- Direct Link: -Link- Risultato test: niente da segnalare [ Edited Tue 21 Jan 2014 - 15:28 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Recuva 1.51.1063 Link winPenPack Aggiornamento dalla versione 1.50.1036 alla 1.51.1063 Home: -Link- Direct Link: -Link- Risultato test: niente da segnalare [ Edited Fri 21 Mar 2014 - 14:30 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Recuva 1.52.1086 Link winPenPack Aggiornamento dalla versione 1.51.1069 alla 1.52.1086 Home: -Link- Direct Link: -Link- Risultato test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Recuva 1.53.1087 Link winPenPack Aggiornamento dalla versione 1.52.1086 alla 1.53.1087 Home: -Link- Direct Link: -Link- Risultato test: niente da segnalare | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1684 | Recuva v1.53.2078 Link winPenPack Aggiornamento dalla versione 1.53.1087 alla 1.53.2078 Sito web: -Link- Direct Link: -Link- [ Edited Wed 27 Apr 2022 - 11:11 ] | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1684 | Recuva v1.53.2083 Link winPenPack Aggiornamento dalla versione 1.53.2078 alla 1.53.2083 Sito web: -Link- Direct Link: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1684 | Recuva v1.53.2095 Link winPenPack Aggiornamento dalla versione 1.53.2083 alla 1.53.2095 Sito web: -Link- Direct Link: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1684 | Recuva v1.53.2096 Link winPenPack Aggiornamento dalla versione 1.53.2095 alla 1.53.2096 Sito web: -Link- Direct Link: -Link- | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1684 | Aggiornamento necessario sulla scheda del programma. Il sito recuva.com non funziona e restituisce un errore 502. Se volete collegarvi al sito del programma cliccate su -Link- | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | eagleman wrote ... Aggiornamento necessario sulla scheda del programma. Il sito recuva.com non funziona e restituisce un errore 502. Se volete collegarvi al sito del programma cliccate su -Link- Fatto! Grazie mille | ||
Go to page <<
