Disable X-Software backups |
goyanes |
Registered Member #27103 Joined: Tue 19 May 2009 - 23:08Posts: 10 | Hi there. On the directory winPenPack\Backups\Firefox I have 5 firefox backups. Is there an option so I can set it just to make 1 backup or even none? Regards, goyanes | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | Hi goyanes, goyanes wrote ... Hi there. On the directory winPenPack\Backups\Firefox I have 5 firefox backups. Is there an option so I can set it just to make 1 backup or even none? Regards, goyanes these backups contain both passwords and bookmarks. We suggest to maintain them for many reasons, first of all the reason that a backup can be always very useful . If you are absolutely sure that you don't want them anymore, you can edit the X-Firefox.ini file. Search the row ";(passwords and bookmarks backup)"; under it you will find all the commands that perform the backups. If you want just 1 backup you can comment (i.e. prefix the row with a ";" character) the 4 rows starting with "DirCopy"; if you don't want any backup, you can comment ALSO the 3 rows starting with "FileCopy". Then you can delete all the folders under winPenPack\Backups\Firefox. But I suggest again to preserve your backups. Nobody knows when, but they will be surely very useful! Best Regards ZioZione | ||
goyanes |
Registered Member #27103 Joined: Tue 19 May 2009 - 23:08Posts: 10 | Hi there. Many thanks. I have the winpenpack directory and sub-directory's always synchronized between 2 computers but just in case I will allow one backup. Regards, goyanes | ||
