[Bug]X-Notepad++ |
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | Software name:X-Notepad++ Link winPenPack:X-Notepad++ 5.9.3 [rev12 aspell] Bug or NOT portability motivation:Impossibility to alter permanently the language via Settings -> Preferences -> tab "General" ->section "Localization" Software license:GNU General Public License [ Edited Fri 12 Aug 2011 - 07:34 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | I think it is enough to change the line 54 from:
;(locale)
to:
;(locale)
---- Communication for the wpp Team ---- @zandet2, è da un paio d'anni che non rivediamo il launcher, forse sarebbe il caso di abbandonare il doppio INI. Il problema è che il programma non riconosce la lingua di sistema. | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | Thank you for this tip. Accordingly, I have made a change in the file X-Notepad++. ini (included in the XDrive folder). Now the app works fine. [ Edited Fri 12 Aug 2011 - 09:39 ] | ||
