Aggiornamento: X-Dev-C++ Go to page >> |
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Dev-C++ 5.1.0.0 link -Link- Aggiornamento dalla 5.0b9.2 alla 5.1.0.0 Web site: -Link- direct download 32 bit: -Link- direct download 64 bit: -Link- source code: -Link- FAQ: -Link- Sourceforge Orvell's main page: -Link- Sourceforge download page: -Link- Sourceforge download portable: -Link- What's new (changelog): Il programmatore Orwell sta portando avanti il lavoro fatto da Bloodshed -Link- migliorando l'IDE "Dev-C++". changelog: Changes - Version 5.1.0.0 - 27 December 2011 This is the first version to fully support 64bit MinGW compilers! Just place one in a folder called 'MinGW64' next to devcpp.exe, Dev will automatically adapt itself to it! When launching for the first time, Dev-C++ will set defaults based on available 32bit or 64bit compilers (favors 64bit). The XP style manifest creator now also supports 64bit. The "Delete Profiling Information" button now does not check for the gmon.out file 60 times a second to keep itself updated. Compiler information in the log now does not show up twice when rebuilding a single file. Project files with dots in their names now do not confuse the executable namer anymore. One more update to the compiler progress window: the warning counter was positioned a bit too much to the right. Added formatting support for 'Sorry Unimplemented' and fixed up 'Unknown escape sequence'. The main form now properly maximises when not starting for the first time. The main form child windows now properly scale themselves when the 'Tip of the Day' window is shown. Slightly lowered startup times again. The code browser toolbar now also shows types and struct members. The code completer and code parser now use symmetric indices and _ID's, making them a lot faster. Code completion cache is now created a bit faster and is smaller. Updated the help file. The tooltip now always shows up when it is supposed to, even the first time. Added a new editor style called Classic Plus, which highlights symbols like { and (. The Code Completion Cache creator can now also be told to cache a selection of files. Updated MinGW32 to GCC 4.6.2. Added TDM-GCC 4.6.1 x64. Added updated Chinese translations by cin.getline. More stuff I forgot about. [ Edited Tue 03 Jan 2012 - 10:47 ] | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | X-Dev-C++ 5.2.0.2 Link winPenPack Aggiornamento dalla 5.1.0.0 alla 5.2.0.2 Home: -Link- Direct link : -Link- (not portable) --- edit zandet2 --- software wpp aggiornato caricato su SF [ Edited Fri 15 Jun 2012 - 21:29 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Dev-C++ 5.2.0.3 Link winPenPack -Link- Aggiornamento dalla 5.2.0.2 alla 5.2.0.3 Web site: -Link- Sourceforge download page: -Link- Direct link download: -Link- (not portable) Not portable installer: file "Dev-Cpp 5.2.0.3 MinGW32 Setup.exe" What's new: Changes - Version 5.2.0.3 - 23 Juni 2012 - Fixed the function argument tip not selecting the function with the right number of arguments first. - Fixed that tip showing in various wrong places. - Added x86 GDB executables to TDM-GCC x64. - Tooltip balloons are now only triggered by words with identifier colors, saving lots of CPU time. - Adding watch variables by hovering over words now only adds words with identifier colors. - Pressing Alt now does not cause static controls to vanish anymore. - This version should scale pictures better on high DPI settings. - Moved to a new selection of built in compiler options. - Added filename tooltips when hovering above tabs. - Closing using the middle mouse button is now only triggered when the mouse is hovering above a tab. - Updated the chinese (TC) translations (by cin.getline). - Fixed editor options not applying function tip timer settings properly, causing crashes when typing. - Updated the greek translations (by migf1). - Various dialogs and buttons are now more spacious, allowing longer translations. - Double clicking on errors now always correctly shows the caret. --- edit zandet2 --- software wpp aggiornato [ Edited Fri 03 Aug 2012 - 19:47 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Dev-C++ 5.3.0.0 Link winPenPack -Link- Aggiornamento dalla 5.2.0.3 alla 5.3.0.0 Web site: -Link- Sourceforge download page: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Dev-C++ 5.3.0.1 Link winPenPack -Link- Aggiornamento dalla 5.3.0.1 alla 5.3.0.1 Web site: -Link- Sourceforge download page: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Dev-C++ 5.3.0.2 Link winPenPack -Link- Aggiornamento dalla 5.3.0.2 alla 5.3.0.2 Web site: -Link- Sourceforge download page: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Dev-C++ 5.3.0.3 Link winPenPack -Link- Aggiornamento dalla 5.3.0.2 alla 5.3.0.3 Web site: -Link- Sourceforge download page: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Dev-C++ 5.3.0.4 Link winPenPack -Link- Aggiornamento dalla 5.3.0.3 alla 5.3.0.4 Web site: -Link- Sourceforge download page: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Dev-C++ 5.4.0 Link winPenPack -Link- Aggiornamento dalla 5.3.0.4 alla 5.4.0 Web site: -Link- Sourceforge download page: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Dev-C++ 5.4.1 Link winPenPack -Link- Aggiornamento dalla 5.4.0 alla 5.4.1 Web site: -Link- Sourceforge download page: -Link- | ||
