X-Gimp 2.6.12 rev 18 does not start on XP
JackL
Thu 16 Feb 2012 - 14:06
Registered Member #6127
Hi,
For some reason, I cannot open the latest gimp - it does not work if I copy it to the rev 17 launcher either...
no clue what's happening - I only noticed that there is additional Lib folder in the main directory (with some ghostscript stuff) otherwise I do not know what's up...
I will keep you posted if I find the bug
JacL
dito
Thu 16 Feb 2012 - 22:27
Registered Member #11533
Also on my laptop with Windows XP Professional Edition SP3 X-Gimp does not start.
Thanks.
barta
Fri 17 Feb 2012 - 07:27
Registered Member #4207
hi guys, I'm experiencing similar troubles with X-LibreOffice 3.5.0 rev8 on XP.
I suspect that it's the same issue you have with X-Gimp.
please, download X-LibreOffice 3.5.0 from here:
and tell me if it works on your system.
when I double-click tha launcher I get this message:
LibreOffice 3.5 - Fatal Error
The application cannot be started
a file status object could not be filled
is the same error you get with X-Gimp?
I suspect that there's some incompatibility with XP and some X-softwares
[ Edited Fri 17 Feb 2012 - 07:28 ]
dito
Sat 18 Feb 2012 - 06:53
I enclose a picture of the error at the opening of X-LibreOffice 3.5 on my XP SP3.
barta
Sat 18 Feb 2012 - 08:07
@dito
that's the same error i get
I suspect the X-gimp and X-libreoffice issues on xp have the same root
