Language switching impossible in the GUI of LibreOffice 3.4.6 [rev7] |
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | At the first start of LibreOffice 3.4.6 [rev7] I changed the language to Germany (for both the GUI and the dictionary). However, the GUI of LibreOffice continues to appear in english language. What must I do to change the language? [ Edited Fri 23 Mar 2012 - 09:58 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | You have made a first installation or an update? I just tested a fresh install and it works after selecting the german language. | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | Unfortunately I have done a downgrade from my installed newer version LibreOffice 3.5.1 [rev9] to the older version LibreOffice 3.4.6 [rev7]. Probably this was the reason for the language problem. Now I have done an upgrade from the older version to the newer version. And it's all ok. | ||
