[moved] why X-firefox 3.6.28 not update ? thanks.
dlusera
Tue 03 Apr 2012 - 14:02
Registered Member #39104
before has a update, following the x-firefox 10.X. so, not already stop update and support for firefox 3.6XX ?
before, my computer slow, need used old version, hope can continue. thanks.
Tue 03 Apr 2012 - 17:06
Registered Member #74
Hi dlusera,
are you talking about this -Link- ?
You can upgrade X-Firefox also from itself (menu Help|About) pressing the button "Check upgrades" (or similar, sorry, I have Italian version...). When Firefox downloads and installs the upgrade DON'T RESTART, but simply close and rerun X-Firefox. Hope this helps
Best Regards
dlusera
Wed 04 Apr 2012 - 11:44
That, I already update. but the portable java new version 6U31 not working. I manual use the java 6U30, is OK. I think that a x-firefoz 3.6X Bugs.
I also test the 6U31 with X-firefox 11.0 Rev5, that working. hope fix the java problems on X-firefox 3.6X.
thanks.
