Sponsored Links
[moved] X-firefox 11.0 Rev5. disable popup info. thanks.
dlusera
Wed 04 Apr 2012 - 11:49
Registered Member #39104
everytime I run X-firefox 11.0 Rev5. must listen the sound 'peep' and the x-firefox popup the info on the traybar. how can I disable this problems ?
before version, I not has this problems.
user known the winpen website and always support it . I think not need special tell the user info. hope can let user choice enabled and disable.
other portable ware also not do this adv.
thanks again.
Wed 04 Apr 2012 - 12:19
Hi dlusera,
the 'popup' is a function introduced in the new launcher 1.5.0; the "beep" sound is not intentional, it depends on the windows settings (mine OS are always setted to mute, so I havent noticed) .
To disable it, you can edit x-firefox.ini and change the option "ShowTrayTip" from true to false.
Instead, if you have a pack, you can disable the popup for all softwares in the pack editing the file XDrive\X-Launcher.cfg adding this lines:
[Options]
ShowTrayTip=false
Hope this help you
