X-Lazarus_0.9.30.4_rev5 Error. Thanks.
dlusera
Fri 24 Aug 2012 - 12:36
Registered Member #39104
I test on windows xp and win 7(64bit) both has same problems. when i try created the new application and press F9, try to complier show me and error
C:\X-Lazarus 0.9.30.4rev5\Bin\Lazarus\lcl\masks.pas(29,22) Fatal: Can't find unit contnrs used by Masks
I try to use default setting or try to fix, but can't be slove. hope help and fix,
rbon
Fri 31 Aug 2012 - 18:11
Registered Member #4134
Hi dlusera,
I suggest You to try another build of Lararus Portable:
- author: Zack Hawkins
- Sougeforge page of author: -Link-
- Sourceforge project page: -Link-
- Lararus Portable ver 0.9.30.4: -Link-
- Lararus Portable Development Test nr. 2 (Update at April 25, 2012) direct download: -Link-
- Softpedia: -Link-
If this build work properly, You can suggest to winPenPack Team some corrections to Lazarus Launcher.
[ Edited Mon 03 Sep 2012 - 16:36 ]
Mon 03 Sep 2012 - 14:54
Hi dlusera,
sorry for the late reply, but it was really hard for me (I do not use Lazarus) to find a solution. The problem is caused by a missing configuration file in the fpc directory, not present even in the original package.
If you can help us, please download the attached zip, and in a clear version of X-Lazarus substitute the original X-Lazarus.exe and X-Lazarus.ini with the files in the zip below:
x-lazarus_test.zip
If the test is ok, we can distribute the complete version.
Thank you.
dlusera
Wed 19 Sep 2012 - 13:58
Sorry, longer reply, this testing version is working now.
just a loading speed is litter slow, compare with old version . may be set too many path.
any how, thanks again.
Wed 19 Sep 2012 - 14:31
Hi dlusera,
glad to see your reply
we will use the new launcher with the next release of X-Lazarus.
Thanks for your test!
