another bug in X-Firefox 18.0.1 [rev7] |
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | After the closure of X-Firefox 18.0.1 [rev7] still remains the folder %AppData%\Mozilla. To solve this problem, it is necessary, in the section [RunAfter] of the file X-Firefox.ini add the following line: DirRemove=@AppDataDir@\Mozilla\Firefox\Extensions [ Edited Thu 24 Jan 2013 - 16:34 ] | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | In the file X-Firefox.ini appears in the section [RunAfter] the following line of code: DirRemove=@AppDataDir@\Mozilla|e After my interpretation that means, that only the empty folders are removed from @AppDataDir@ on exit. My first question is, if this is the meaning of the option "e"? Means the removal of empty folders, that the folder Mozilla itself must be empty, i.e. the folder Mozilla doesn't contain any subfolders (first case)? And does this imply also the case, if the folder Mozilla contains some subfolders, which then must be all empty, so that the above code can be executed (second case)? | ||
Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 | Hi dropper, the meanings of "|e" parameters is: delete only if main folder and all of subfolders are empty (the second case). | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | Thanks for the prompt reply. I still have another question in connection with the section [RunAfter]. On one hand the character "@" is used and on the other the character "$". Is there a reason for this decision or could not use instead of $LocalAppData$ simply @LocalAppData@? [ Edited Wed 06 Feb 2013 - 16:11 ] | ||
