strange behaviour of the upgrade manager Go to page >> |
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | Several times I have found that the upgrage manager makes false statements. For example,it was shown me with my upgrade to LibreOffice 4.0.0, that a newer version (here: 3.6.5 and 3.5.7) is present. That's obviously false. | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | Hi dropper, our upgrade manager has this approach: It checks the release number of "OFFICIALLY DOWNLOADABLE" programs and not the BETA/TEST versions. So, if you have already installed X-libreoffice 4.0.0 (not yet offically released), the manager checks the number of your release with the official one. In this check, It looks different, so you have the alert of a new release is available! in reality you have a DIFFERENT release! This behaviour sometimes happens also when we have 2 versions of same program in download (i.e. X-keepass 1.* and X-Keepass 2.*) Hope this feedback can hepls to understand the "misundersanding" | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | To my knowledge the version LibreOffice v4.0.0 for is an official release, which has been released since 07/02/2013 for downloading. Accordingly, your argumentation does not be the cause of the incorrect display of the upgrade manager. | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | dropper wrote ... To my knowledge the version LibreOffice v4.0.0 for is an official release, which has been released since 07/02/2013 for downloading. SNIP I'm talking about X-Libreoffice, not Libreoffice Our Updates are monitored only for Portable versions, tested and "officially linked" in our download area. | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | Personally I would say, that X-LibreOffice 4.0.0 [rev14] is offered as an official release in the download area, because I can't find a converse hint. Accordingly, your argumentation is not quite understandable for me. [ Edited Thu 14 Feb 2013 - 12:04 ] | ||
duwil |
Registered Member #6659 Joined: Tue 23 Oct 2007 - 18:34Posts: 42 | Open wpp menu window, select X-LibreOffice, press F5 to open properties, select tab Info, paste http://www.winpenpack.com/main/download.php?view.1354 in wPP Download Page box. This solved for me. [ Edited Thu 14 Feb 2013 - 15:38 ] | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | I have tried your proposed solution, but it doesn't work. Incidentally, this manual solution (in cases where it work) would also not eliminate the fundamental problem of incorrect display in the Upgrade Manager, because it is necessary to alter the entries in the wpp menu every time again. | ||
duwil |
Registered Member #6659 Joined: Tue 23 Oct 2007 - 18:34Posts: 42 | Indeed, it does work for me ... no need to alter entries every time again, just once. Is it possible you're running an old wpp launcher version? Mine is 2.8.67.2350 on a win7 pc. --- | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | dropper wrote ... Personally I would say, that X-LibreOffice 4.0.0 [rev14] is offered as an official release in the download area, because I can't find a converse hint. dropper, the Official download link is the following: -Link- and was officially added on February 12th before this date, it was not yet official. (this explain my previous sentences... apologies) dropper wrote ... Accordingly, your argumentation is not quite understandable for me. Actually, because of the chamge of MAIN release (3.5.X -> 4.0.X), the only way to have your wPP update working properly is: Open wpp menu window, select X-LibreOffice, press F5 to open properties, select tab Info, paste http://www.winpenpack.com/en/download.php?view.1354 in wPP Download Page box. This forks fine for me, since long time ago. | ||
dropper |
Registered Member #39636 Joined: Tue 15 Feb 2011 - 23:47Posts: 165 | I also use the winPenPack Launcher version 2.8.67.2350 on a computer with an installed OS Windows XP SP3. But in my case it doesn't work as I have mentioned above. Regarding my remark in connection with the necessity of an alteration every time again I meant, that you must make these manually entries for every new app with such an issue in the upgrade manager. And also in the case, if the link will be changed, you must again copy this new link. [ Edited Thu 14 Feb 2013 - 16:46 ] | ||
