Aggiornamento: X-Avidemux Go to page << >> |
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Avidemux 2.6.4 rc1 Link winPenPack -Link- Aggiornamento dall versione 2.6.3 alla 2.6.4 rc1 Home: -Link- Forum: -Link- Nightly Builds win32: -Link- Direct download r8682: -Link- Note: - il numero interno di versione della build r8682 è ancora il 2.6.3 ... - ripristinata la traduzione italiana (subfolder i18n, file avidemux_it.qm) - non è ancora la versione definitiva: questa build serve per fare dei tests. | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Avidemux 2.6.4 Link winPenPack -Link- Aggiornamento dalla versione 2.6.3 alla 2.6.4 Home: -Link- Download page (web site): -Link- Sourceforge download page: -Link- Sourceforge download page ver 2.6.4: -Link- Direct Link (not portable): -Link- What's New in rel 2.6.4: * Switched to mxe-octave for win32 build, that fixes most of the crashes on win32 * Better compatibility with AAC in mpeg TS * Translations re-enabled * Fixed a bug in x264 which could make encoding abort right at the beginning * Fixed msharpen when width was not a multiple of 8 * Added camtasia codec support * Fixed VC1 in TS indexing * Properly clear things when loading a new video * Report proper audio duration for mpeg PS/TS * Report proper audio duration for mpeg PS/TS * Ass/ssa filter re-enabled | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Avidemux 2.6.5 Link winPenPack -Link- Aggiornamento dalla versione 2.6.4 alla 2.6.5 Home: -Link- Download page (web site): -Link- Sourceforge download page: -Link- Direct Link (not portable): -Link- What's New changelog for ver 2.6.5: -Link- | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Avidemux 2.6.6 Link winPenPack -Link- Aggiornamento dalla versione 2.6.3 alla 2.6.6 Home: -Link- Download page (web site): -Link- Download Nightly builds: -Link- Direct Download 32 bit - build 8941: -Link- What's new: -Link- Nota_1: La versione 2.6.6 è la build 8941 (build 2.6.6.8941 del 28-09-2013). Nota_2: La build 8941 è essenzialmente una build Bugfixes (correzione di errori vari: vedi What's new) | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | riporto in primo piano questo post perché ho provato l'attuale versione in DL (2.6.3) e non si avvia sul mio sistema con Win 7 Pro 64bit. Non mi da nessun tipo di errore, quindi non riesco ad essere più preciso | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | Taf wrote ... riporto in primo piano questo post perché ho provato l'attuale versione in DL (2.6.3) e non si avvia sul mio sistema con Win 7 Pro 64bit. Non mi da nessun tipo di errore, quindi non riesco ad essere più preciso In effetti lo sviluppatore sta portando avanti 3 linee distinte di versioni per Windows (Nightly Builds folder): 1. win32 (portable) -Link- 2. win64 (portable) -Link- 3. win_installer -Link- Prova ad usare la versione a 64 bit, anche se la versione a 32 bit di Avidemux dovrebbe comunque funzionare su un sistema Windows a 64 bit. | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Avidemux 2.6.7 Link winPenPack -Link- Aggiornamento dalla versione 2.6.6 alla 2.6.7 Home: -Link- Download page: -Link- Direct download 32 bit not portable: -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Wed 08 Jan 2014 - 23:45 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Avidemux 2.6.8 Link winPenPack -Link- Aggiornamento dalla versione 2.6.7 alla 2.6.8 Home: -Link- Download page: -Link- Direct download 32 bit not portable: -Link- La versione è la 2.6.8 build 9045 del 12/03/2013. NB_1 il programma non è ancora ufficialmente in download NB_2 il link per il download è un po' particolare ed è il seguente: (http://download.berlios.de/avidemux/avidemux_2.6.8_win32.exe/from_sourceforge) e va digitato come appare, ovviamente senza le parentesi. ---------------------Edit---by----rbon-------------------------------------------------------------- ... Nel frattempo lo sviluppatore ha rilasciato ufficialmente la nuova versione 2.6.8, ecco i link aggiornati: Home: -Link- Download page: -Link- Direct download 32 bit not portable: -Link- [ Edited Fri 14 Mar 2014 - 11:52 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Avidemux 2.6.8 v2 Link winPenPack -Link- Aggiornamento dalla versione 2.6.8 alla 2.6.8 v2 Home: -Link- Download page: -Link- Direct download 32 bit not portable: -Link- | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 910 | X-Avidemux 2.6.9 v2 Link winPenPack -Link- Aggiornamento dalla versione 2.6.8 v2 alla 2.6.9 v2 Home: -Link- Sourceforge download page: -Link- Direct download 32 bit not portable: -Link- Direct download 64 bit not portable: -Link- Note Version for Win32 is NOT XP compatible. | ||
