Aggiornamento: X-Stellarium
Go to page   <<        >>
Mon 09 Sep 2013 - 22:32
Registered Member #675
X-Stellarium 0.12.3
Link winPenPack
Aggiornamento dalla versione 0.12.2 alla 0.12.3
Home: -Link-
Direct link: -Link-
--- edit zandet2 ---
software wpp aggiornato
[ Edited Mon 16 Sep 2013 - 22:36 ]
Sun 29 Sep 2013 - 21:42
X-Stellarium 0.12.4
Link winPenPack
Aggiornamento dalla versione 0.12.3 alla 0.12.4
Home: -Link-
Direct link: -Link-
[ Edited Fri 04 Oct 2013 - 23:38 ]
Sat 19 Jul 2014 - 14:27
X-Stellarium 0.13.0
Link winPenPack
Aggiornamento dalla versione 0.12.4 alla 0.13.0
Home: -Link-
Direct link: -Link-
rbon
Sun 19 Oct 2014 - 17:22
Registered Member #4134
X-Stellarium 0.13.1
Link winPenPack -Link-
Aggiornamento dalla versione 0.13.0 alla 0.13.1
Home: -Link-
Download page: -Link-
Direct link not portable: -Link-
What's new: -Link-
[ Edited Wed 22 Oct 2014 - 20:32 ]
rbon
Tue 20 Jan 2015 - 22:10
X-Stellarium 0.13.2
Aggiornamento dalla versione 0.13.1 alla 0.13.2
Home: -Link-
Sourceforge download page: -Link-
What's new: -Link-
Sun 26 Apr 2015 - 21:47
X-Stellarium 0.13.3
Link winPenPack
Aggiornamento dalla versione 0.13.0 alla 0.13.3
Home: -Link-
Direct link: -Link-
rbon
Fri 23 Oct 2015 - 19:28
Rcs wrote ...
X-Stellarium 0.13.3
Link winPenPack
Home: -Link-
Direct link: -Link-
Per favore potreste aggiornare il programma in download?
Grazie.
rbon
Fri 30 Oct 2015 - 15:11
X-Stellarium 0.14.0
Aggiornamento dalla versione 0.13.3 alla 0.14.0
Home: -Link-
Direct link 32 bit not portable: -Link-
Direct link 64 bit not portable: -Link-
What's new: -Link-
Complete what's new at Launchpad: -Link-
Launchpad download page: -Link-
rbon
Wed 02 Dec 2015 - 12:55
X-Stellarium 0.14.1
Aggiornamento dalla versione 0.14.0 alla 0.14.1
Home: -Link-
Stellarium at Launchpad.net (Developer page): -Link-
Nota
le versioni per Windows indicate in download sono state compilate con Microsoft Visual Studio 2013.
[ Edited Wed 02 Dec 2015 - 18:08 ]
rbon
Fri 08 Jan 2016 - 19:09
X-Stellarium 0.14.2
Aggiornamento dalla versione 0.14.1 alla 0.14.2
Home: -Link-
Stellarium mirror at Sourceforge: -Link-
What's new:
Changelog:
List of changes between version 0.14.1 and 0.14.2:
- Reduce planet brightness in daylight (LP: #1503248)
- Fixed perspective mode with offset viewport in scenery3d (LP: #1509728)
- Fixed wrong altitudes for some locations (LP: #1530759)
- Fixed some skyculture links
- Fixed editing some shortcut keys (LP: #1530567)
- Fixed drawing reticle for telescope (LP: #1526348)
- Fixed wrong altitude of culmination in Observability plugin (LP: #1531561)
- Fixed connection troubles in Telescope Control Plugin on Windows (LP: #1530372)
- Refactoring coloring markers of the DSO
- Removed info about Moon phases (avoid inconsistency for strings).
- Updated default config options
- Updated icons for View dialog
- Updated Stellarium DSO Catalog
- Added list of dwarf galaxies (Search Tool)
- Added improvements in Scenery 3D plugin
Note:
- Stellarium classic version 32 bit: Stellarium 0.14.2 for Windows (32-bit; Windows XP) based on Qt 5.5.1 (MinGW GCC 4.9.2; OpenGL) with audio support. This is classic Windows application with support 3rd-party plugins;
- Stellarium 64 bit: Stellarium 0.14.2 for Windows (64-bit) based on Qt 5.5.1 (Visual Studio Express 2013) with audio support.
Go to page   <<        >>
