Aggiornamento: X-Iron Go to page << >> |
Bourne |
Registered Member #4287 Joined: Fri 20 Apr 2007 - 16:55Posts: 571 | Scaricato X-Iron 38.0.2050.0 ma, siccome contiene i binari 32 bit di Iron, io volevo provare il launcher con quelli a 64bit della corrispondente versione; lascia questo: HKEY_USERS\S-1-5-21-3668210609-2088346886-2201473197-1001\Software\Google\ | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Iron 39.0.2100.0 Link winPenPack Aggiornamento dalla versione 38.0.2050.0 alla 39.0.2100.0 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Iron 40.0.2150.0 Link winPenPack Aggiornamento dalla versione 39.0.2100.0 alla 40.0.2150.0 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Iron 41.0.2200.0 Link winPenPack Aggiornamento dalla versione 40.0.2150.0 alla 41.0.2200.0 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Iron 42.0.2250.1 Link winPenPack Aggiornamento dalla versione 41.0.2200.0 alla 42.0.2250.1 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Iron 44.0.2350.0 Link winPenPack Aggiornamento dalla versione 42.0.2250.1 alla 44.0.2350.0 Home: -Link- Direct link: -Link- [ Edited Tue 11 Aug 2015 - 19:24 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Iron 46.0.2450.0 Link winPenPack Aggiornamento dalla versione 44.0.2350.0 alla 46.0.2450.0 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Iron 47.0.2500.0 Link winPenPack Aggiornamento dalla versione 46.0.2450.0 alla 47.0.2500.0 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Iron 48.0.2550.0 Link winPenPack Aggiornamento dalla versione 47.0.2500.0 alla 48.0.2550.0 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Iron 48.0.2550.1 Link winPenPack Aggiornamento dalla versione 48.0.2550.0 alla 48.0.2550.1 Home: -Link- Direct link: -Link- | ||
