Aggiornamento: PDF-XChange Viewer Portable Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.308.2 Link winPenPack Aggiornamento dalla versione 2.5.308.1 alla 2.5.308.2 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.309 Link winPenPack Aggiornamento dalla versione 2.5.308.2 alla 2.5.309 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.310 Link winPenPack Aggiornamento dalla versione 2.5.309 alla 2.5.310 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.311 Link winPenPack Aggiornamento dalla versione 2.5.310 alla 2.5.311 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.312 Link winPenPack Aggiornamento dalla versione 2.5.311 alla 2.5.312 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare [ Edited Tue 03 Feb 2015 - 16:56 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.312.1 Link winPenPack Aggiornamento dalla versione 2.5.312 alla 2.5.312.1 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.313.0 Link winPenPack Aggiornamento dalla versione 2.5.312.1 alla 2.5.313.0 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.313.1 Link winPenPack Aggiornamento dalla versione 2.5.313.0 alla 2.5.313.1 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.314.0 Link winPenPack Aggiornamento dalla versione 2.5.313.1 alla 2.5.314.0 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.315.0 Link winPenPack Aggiornamento dalla versione 2.5.314 alla 2.5.315.0 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
