Aggiornamento: PDF-XChange Viewer Portable Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.316.0 Link winPenPack Aggiornamento dalla versione 2.5.315 alla 2.5.316.0 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.316.1 Link winPenPack Aggiornamento dalla versione 2.5.316.0 alla 2.5.316.1 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.317 Link winPenPack Aggiornamento dalla versione 2.5.316.1 alla 2.5.317 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.317.1 Link winPenPack Aggiornamento dalla versione 2.5.317 alla 2.5.317.1 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.318 Link winPenPack Aggiornamento dalla versione 2.5.317.1 alla 2.5.318 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.318.1 Link winPenPack Aggiornamento dalla versione 2.5.318 alla 2.5.318.1 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.319.0 Link winPenPack Aggiornamento dalla versione 2.5.318.1 alla 2.5.319.0 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.320.1 Link winPenPack Aggiornamento dalla versione 2.5.319.0 alla 2.5.320.1 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare [ Edited Sat 11 Feb 2017 - 16:02 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.321.0 Link winPenPack Aggiornamento dalla versione 2.5.320.1 alla 2.5.321.0 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | PDF-XChange Viewer Portable 2.5.322.0 Link winPenPack Aggiornamento dalla versione 2.5.321.0 alla 2.5.322.0 Home: -Link- Direct Link: -Link- OCR plugin: -Link- Risultato Test: niente da segnalare | ||
